Fuel Pump/Line issue
Old May 15, 2017 | 05:04 PM
BenjF's Avatar
Default Fuel Pump/Line issue
Hi all,
First post but hopefully you can help me!
Thats from my car above. The fuel line connector has managed to snap away from the pump and is currently in the end of the fuel line pipe.
This is an image of a pump on eBay. It's the pipe on the left where the connector has snapped. Any idea if that connector detaches and if so, where I can source one from?
Thanks in advance! Hopefully that makes sense.
Old May 15, 2017 | 07:06 PM
Dell Gailey's Avatar
I'm a bit confused. Are you sure you posted in the correct forum. My X type fuel pump looks like =
Old May 15, 2017 | 07:09 PM
Fraking site, can't post pics unless I log in and out a dozen or more times
Old May 15, 2017 | 09:48 PM
avern1's Avatar
I believe that is the X-Type Diesel high pressure pump
Old May 16, 2017 | 02:07 AM
BenjF's Avatar
So does that part come separately do you know? (The bit that is broken). Just can't seem to find it anywhere.
Old May 16, 2017 | 12:01 PM
wa3ra's Avatar
Try bertieboy on the UK site; he's always breaking X-types and should have a few used ones floating around!
Old May 17, 2017 | 01:38 PM
Also, a source may be contacting dephi (pump maker) directly to see if it replaceable.
Old May 18, 2017 | 07:50 AM
BenjF's Avatar
Cheers for the replies. I just need to know what this part is?
https://ibb.co/ksKvqk
https://ibb.co/fZWKGQ
https://ibb.co/n0P6wQ
There's no part number or anything, and I can't seem to find it anywhere?
