Fuel pump and power to fuel pump
Old Feb 20, 2018 | 02:01 PM
Silo's Avatar
Default Fuel pump and power to fuel pump
Good day all I inquired earlier about the locking mechanism on the rear door well that is still a problem but now another problem came up I placed a hi pressure fuel pump inline from the tank and disconnected the fuel pump inside the tank now few days later the car went and stalled the pump doesnt work any more and there is no power going to the fuel pump wires any suggestions or advice to solve my problem ?
_______________
2006 X-Type 3 ltr V6 (added by GGG)
Old Feb 20, 2018 | 02:47 PM
You have already posted an Intro so I've moved you question from New Member Area - Intro a MUST forum to X-Type forum. This is the place to post questions about your model.
Old Feb 20, 2018 | 04:13 PM
wa3ra's Avatar
Did you wire the high-pressure pump to the same line as the in-tank pump? That little external pump draws a lot of current; you've most likely blown the fuse.
Don't just put a higher-amp fuse in, you'll need to run a heavier wire back to the pump.
Old Feb 20, 2018 | 11:50 PM
Silo's Avatar
Good day yes I did connect it directly on the old fuel pump wires and I did go thru all the fuses there was one that was blown a 10amp fuse but I replaced after taking out the pump and running the original pump in the dank but still no luck on that en so i thought it might be the relay ?
Old Jan 14, 2019 | 11:25 PM
Lady Penelope's Avatar
Look in thus area and note your model year :
https://www.jaguarclassicparts.com/u...tems/fuel-tank
As the fuel pump fails in the brushes arcing it will pit the relay power contacts and not allow enough current to run a new pump
It will also burn the connector on the pump doing the same
Some X308s have a noise suppressor at this final connector
The original relay will click and close in troubleshooting but no joy
Relay swapping options for troubleshooting ?
Old Jan 21, 2019 | 04:02 PM
astromorg's Avatar
A couple of belated points.
The fuel pump power supply is a PWM one from the fuel pump module that varies the fuel pump speed depending on the engine's fuel requirement.
Even if your new pump accepts that, it cannot duplicate the dual pump arrangement in the tank - one variable speed electric pump in one side of the saddle tank and one venturi type pump in the other side powered by a fuel flow leakoff from the electric pump.
Old Jan 21, 2019 | 05:03 PM
dennis black's Avatar
can you get a regular pump
Poet
Apr 11, 2022 06:51 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
82WingNut
Apr 9, 2017 10:22 AM
Sean Roberts
Jan 1, 2017 10:31 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
