fuse info heads up . Also thanks Thermo
Old May 1, 2012 | 05:53 AM
Jagmag's Avatar
Default fuse info heads up . Also thanks Thermo
Just a heads up when you check your fuses use a flash light . My low beam was out after i replaced it still didnt come on . So i checked fuse seemed fine until i looked with flash light. Also thanks Thermo for info.
Old May 1, 2012 | 06:55 AM
Thermo's Avatar
Veteran: Navy
Jagman, not a problem. I just pass on the information. What you experienced is why a lot of electricians use a multimeter to verify fuses good. Visually they may look fine, but internally they are shot. The other thing you can do is if you don't have a multimeter, take a circuit that works of equal or lower current rating, temporarily put the fuse in question there. If the circuit still works, then the fuse is good. Reinstall the original fuse. If you use a circuit with a higher rated fuse, you may blow the fuse due to making it try to pass too much current and then you have a definite bad fuse.
eurotire
Sep 18, 2015 07:27 AM
Ipc838
Sep 13, 2015 03:27 PM
tvholden
Sep 12, 2015 11:13 AM
Wolfy
Sep 11, 2015 06:27 AM
motorhead69
Sep 9, 2015 10:04 AM
