Fuse placement guide?? Right side parking lights suddenly quit working
Old Apr 22, 2010 | 08:26 PM
Xtype'02's Avatar
Default Fuse placement guide?? Right side parking lights suddenly quit working
I need a guide for fuse placements in a 2002 xtype I tried to download the owners manual but it doesn't work. My right side parking light, side markers and part of the headlights wont work....Brake light and turn signals don't work. I cant find the fuse that controls the right side parking lights.......Can anyone just tell me where it is??
Old Apr 23, 2010 | 06:13 AM
Thermo's Avatar
Veteran: Navy
I would start with checking fuse F21 to make sure that is good. From there, check fuse F63 to make sure that one is good. If both of those are good, then you are most likely looking at a plug that has come disconnected. The plug would be located near the headlight (inboard of the headlight). The final thing that it could be is the ground wire for these things. If you access the side marker light, follow the black wire to where it attaches to the body. This will be under the right hand headlight (which will most likely require removing the front bumper cover and then sliding the headlight out of the way).
Hope this helps.
BrentGardner
29
Dec 16, 2024 12:13 AM
chipnping
Mar 8, 2016 10:33 PM
johnnie ryall
Oct 19, 2015 09:44 PM
tberg
Aug 31, 2015 04:33 PM
Jandreu
Aug 29, 2015 07:31 PM
