Generator light
Old Feb 19, 2009 | 08:35 AM
laurielalone's Avatar
Default Generator light
Hi everyone. 04 3.0 w/50,500 mls. Last night after driving 45 mins w/ A/C and headlamps on, the generator light came on. Got home, shut off car for 5 mins at most. When i started back up, warning light was no longer on. Went to repair shop the morning and they tested battery, which was very strong at 14.5 amps, 12.5 with A/C cranked and lights on. They told me it must have been some type of glitch! No fault found....Any thoughts on this?
Old Feb 19, 2009 | 09:06 AM
Jayj's Avatar
Probably battery connectors were loose and corrosive? I had a same problem and it went away when I cleaned connectors from corrosion and tightened them.
Old Feb 19, 2009 | 09:14 AM
thank you...there is a bit of crap on one of the posts. will clean it up today
Old Feb 19, 2009 | 06:55 PM
Striker27's Avatar
I have a similar problem with a light that comes and goes!!! The dealer and myself have been unable to find the fault!!!
Old Feb 19, 2009 | 06:59 PM
Real_Tech's Avatar
Codes would help narrow it down. Even though the check engine light isn't on the ECM controls the charging system and if the battery light was on it will have set a code in the ECM. Battery lights are very hard to diagnose in an X-type. Hands on diagnosis at a Jaguar dealer is the best way to go.
Forcedair1
Sep 8, 2025 01:57 PM
Wolfy
May 28, 2024 08:06 AM
Jpav27
Jul 31, 2022 06:43 AM
jehart49
Sep 12, 2015 05:36 PM
convincor
Sep 10, 2015 06:50 AM
