Hard reboot of battery / ecu
Old Feb 23, 2024 | 01:00 PM
NYCJAG2006's Avatar
Default Hard reboot of battery / ecu
Can someone please give me a step by step way of doing a hard reboot please. I’ve searched and keep coming up with different ways. Want to try to see if this may solve my problem. Thx
Old Feb 23, 2024 | 08:21 PM
Dell Gailey's Avatar
Old Feb 24, 2024 | 09:55 PM
Ronks2's Avatar
I have three quick questions on this reset.
1. Is there a trick on how can I get my radio code before I do this?
2. I have heard that as a precaution you should put a diode or similar device to absorb the pulse. Anyone ever do this or have trouble frying their ECU?
3. If this does not work, where can I send an ECU to get rebuilt?
Thanks,
Ronk
Old Feb 25, 2024 | 02:23 PM
JagV8's Avatar
I'm wondering why you want to do it at all?
Also, the "ECU" (PCM) is a very robust item so usually needs no repair. What's wrong with it?
Old Feb 25, 2024 | 03:08 PM
Ronks2's Avatar
Hi JagV8,
Was going to open up a new window after pulling my plugs, but where I have you available I will run with it.
I was forever getting lean on bank 1 and 2. Did a smoke test, fuel trim test and sprayed the whole engine down with carb, brake, either and MAF cleaner and addressed all of the air leaks i could find. Now I am still regularly getting bank 2 lean and sometimes bank 1 lean, so marginally better.
Did the 100k X type service and replaced the MAF sensor, EGR, brake booster hose and their o-rings, 4 O2 sensors, fuel and air filter, battery cables and the two large o-rings that usually leak. All in have a thousand into the cost of the car for five years use so didn't want to be bothered chasing one thing at a time. I did get O2 sensor codes in the past which is why i replaced them.
I have had the car 5 years and just hit 115k miles, so I figured I would do a new set of plugs and replace at least the upper intake gaskets while i am at it.
Any other ideas on the lean codes? Was thinking if all else checks out correct look into a new ECU if cheap enough. I do live in Florida and the car has hit a few nasty puddles and i am running out of ideas. Would be interested in any other thoughts as well.
Regards,
Ron
Old Feb 26, 2024 | 10:18 AM
JagV8's Avatar
I'd stop suspecting the PCM unless you have seriously good reasons e.g. it's wet.
Old Mar 4, 2024 | 06:33 AM
Ronks2's Avatar
In the back of my mind i am wondering about the being wet, because I live in Florida. I did have the misfortune of hitting a big enough puddle that my feet actually got wet. Water pushed in from the splash around the power brake booster, but the car did not sputter, stall or die, so I am not 100 percent sure on the ECU getting damaged.
We are pulling the plugs and intake today and will report back with what we find.
As always, i look forward to your reply as well as everyone else's.
Have a great morning,
Ron
jim_63219
May 18, 2023 08:25 AM
nielda800
Mar 11, 2019 12:17 PM
rjesq
Jun 9, 2018 09:25 PM
charlie786
Jul 16, 2013 11:57 AM
Randy
Dec 26, 2012 07:08 PM
