Hazy headlight remedy!
Old Jul 10, 2013 | 03:47 AM
Bryandreg's Avatar
I used the 3M kit and cleared up the lens but the fish eye lens inside is foggy on one side. How do I clean the internal lens up?
Old Aug 1, 2014 | 12:31 PM
Kris9884's Avatar
I've found the best LONG TERM results are using a body compound like you would if you were wet sanding a car. Then buffing with plastic filler. Lastly waxing over it with a sealant/clear coat repair, sounds weird but I'm about a year in and no issues. Looks like glass still.
Old Aug 1, 2014 | 07:21 PM
PanamaJag's Avatar
If you go the toothpaste route, don't forget to floss!!
Old Aug 28, 2014 | 01:57 PM
Meouch's Avatar
Yeah - toothpaste can work. Used to use it on chrome. It depends on how bad the haze is. I used it on my headlights... better but not perfect - toothbrush with toothpaste - maybe if I spent more time... or get that buffing attachment for my drill...
Old Sep 4, 2014 | 08:52 AM
nobodyspecial's Avatar
Here is my results with the 3M kit. My lenses were bad! They look better than the picture shows, too! I had very poor lighting for the pictures.
Before:
After:
Old Mar 9, 2017 | 11:14 PM
Dell Gailey's Avatar
Default Hazy headlight permanent fix
After wet (water and mild dish soap) sanding very lightly with 1000 grit sand paper, clean thoughly, use Krylon Fusion for Plastic top coating, non yellowing, UV protection. Use very light coats several times, assuring it is dryed between coats. The initial coat will show slight "orange peeling" don't fret it blends out as you progress.
This is a permanent solution. I have never had to repeat it, but hey, if I do, pretty inexpensive for around $8 U.S., and I've done 3-4 cars per can.
Old Mar 9, 2017 | 11:27 PM
Default Additional photos of permanent solution
Photos of my mother's Bonneville. Before and after.
Attached Thumbnails  Hazy headlight remedy!-20160526_162238.jpg    Hazy headlight remedy!-20160526_165348.jpg    Hazy headlight remedy!-20160526_171612.jpg
Old Mar 11, 2017 | 08:57 AM
  #28
DaveJessop's Avatar
My old Kia failed the MOT because of cloudy headlights - took it to a local garage and they ground and polished the set of lens for £30 and it took about 20 minutes
Probably cheaper to do it yourself with a kit but I'm lazy
Old May 20, 2017 | 12:37 PM
Another before and after fix, using my permanent resolution.
Before
After
Old Jul 4, 2017 | 07:38 PM
  #30
Default Another Permanent Fix
Before
After
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
sdelliott58
Sep 28, 2015 11:21 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
