Head Unit issues please help
Old Jan 28, 2008 | 04:39 PM
FactoryJaguarTech's Avatar
Default RE: Head Unit issues please help
Sounds like bull to me Ross. The X-type speakers generally go out with each other. I would start by replacing them. Not with factory ones mind you. For half the price and twice the quality you can get a set at best buy or the like.
The head unit puts the sound out to the amp in the rear. The amp then outputs to the speakers. The amp will normally work or not. So if you have sound from one speaker, replace the speakers.
And the head unit for nav vehicles is indeed 5g's. If that ever goes, I would start looking at junkyards first.
Old Jan 28, 2008 | 06:36 PM
H20boy's Avatar
^ above, and if you still don't have sound after replacing the speakers, it should be just a matter of replacing the amplifier, again...I recommend a brand other than JAGUAR, which should be easily replaced at any car audio shop, and at a much lower cost. I don't think there is any funny wiring like 'fiber optic' to worry about in your X.
Old Jan 28, 2008 | 06:50 PM
aloiseau10's Avatar
I actually had the same problem in my 2002 x-type. My drivers side rear speaker stopped working completly. I went to Best Buy, got a pair of new speakers for the front [Alpine Type S] for $120 and a pair for the back [Alpine Type S as well] for $140. They were pretty easy to install and there are a ton of threads on these forums with detailed instructions.
Everything works fine now and the sound qualities pretty good.
Old Jan 29, 2008 | 09:44 PM
jvegas's Avatar
welcome ross, and i hope the speakers work for you. please stop back and read through the forums help where you can, and learn from all the great people on here. oh, and let us know if the speakers work when you are done.
Old Jan 29, 2008 | 10:04 PM
Master Deep's Avatar
My headunit is skipping. I don't have nav. Dealer told me that radio is considered a "throw away" part. So a new one would be $400 and I should just learn to put up with a skipping cd player. Used a cd lens cleaner and it did nothing. It also tends to start skipping more on bumps/pot holes. Anyone know what could be up?
I did a cheap fix by getting a itrip for my ipod for $30.
But replace the speakers and let us know if they work. You may have just blown out your speakers. Don't get really nice speakers unless you are upgrading your amp also because they are overkill then if not powered correctly.
Wolfy
May 28, 2024 08:06 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
