headlight
Old Jan 2, 2013 | 04:11 AM
pab18's Avatar
Default headlight
jaguar x type headlights not working also high beam not staying on any ideas
Old Jan 2, 2013 | 04:25 AM
Welcome to the forum pab18,
I've moved your headlight question to the X-Type tech section where it will be seen by more members with the same model.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post something about yourself and your X-Type for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Hope the headlight is an easy fix.
Old Jan 2, 2013 | 07:56 AM
AlfaVeloce's Avatar
Is the problem that you can switch to high beam but it goes back to low beam as soon as you release the switch? When ours did that it was a fuse. And the owner's manual was wrong about which fuse it was in the fuse bank. If I can find the info on that I'll post it.
Old Jan 2, 2013 | 09:40 AM
WayneCountyBill's Avatar
I have to double click on my stalk to have the high beams stay "on."
Old Jan 2, 2013 | 10:51 AM
Thermo's Avatar
Veteran: Navy
pab18, let me look at the drawings to confirm a few things and we will be able to get you hooked up. On a side note, what year car are we looking at here just to make sure we are looking at the correct diagrams as there were minor changes wiring wise made to the car over the years.
From the sounds of things, should be a fairly easy thing to fix. Sounding like separate issues between the low beams and the high beams. But, we will get it figured out.
Old Jan 3, 2013 | 03:10 PM
pab18's Avatar
hi thanks car has picture problem high flashes wont stay on and we have no normal head lights only side lights no normal head lights on both sides hope is helps thanks again paul
Old Jan 3, 2013 | 03:12 PM
pab18's Avatar
car is a xtype 3.0 sport 52 plate seperate lights has in picture
Old Jan 3, 2013 | 03:16 PM
pab18's Avatar
goes back has you stay but also have no low beam light at all on both sides thanks paul
Old Jan 3, 2013 | 11:31 PM
AlfaVeloce's Avatar
I still suspect fuse as that deal where the main beam works only with the switched pulled in is just like the problem I had. Difference is that my dip beams still worked. There is a dip beam relay in the fuse box in the engine compartment that could use a check.
Have you searched the X type forum? I put in a seach term of "headlight fuse" and got over 50 threads back that mention headlights along with fuses. That's over 50 just in the X Type forum. I bet someone has seen and solved your problem already. There is also a thread that discusses headlight circuit troubleshooting. Good luck!
Old Jan 4, 2013 | 07:09 AM
pab18's Avatar
i have identified fuse f 67 has problem its blows even without the head light switch on
it also controls the battery back up sounder , transit relay, auxiliary vacuum pump control if any one help tell me where any of theses are then i could try disconnecting each one in turn thanks to all for advice paul
Old Jan 4, 2013 | 05:09 PM
Thermo's Avatar
Veteran: Navy
pab, well, lets see if we can narrow things down a little bit for you. First we are going to try removing a few relays and seeing if we can eliminate a bunch of wiring from your list of possible problems. You will need to start with removing relay R8 and R9 from the engine fuse box. I would also unplug the security sounder of the car (passenger corner of the dash for your car, tucked up in there). I would then re-install the fuse (5 amp only). Does the fuse blow now? If yes, then let me know and we will take you from there. If it doesn't, install relay R8 back into its slot. Did the fuse blow now? If yes, then you have a problem with your TCM or the relay for the TCM is bad (use relay R9 in place of R8 after installing a new fuse and seeing if the fuse blows now, if no, bad relay, replace the relay that was originally R8). If R8 did not blow the fuse, install relay R9. Like before, if the fuse blows, use relay R8 in R9's spot and see if a new fuse blows now.
If you can get both of those relays installed and the fuse does not blow, then odds are it is the sounder that is bad. You can confirm things by connecting up the sounder and seeing if the fuse blows.
It is possible that relay R9 (dip/low beam headlights) has failed internally and now it is trying to power the headlights even with the headlight switch in the off position which is more power than the fuse is allowed to handle, causing it to fail. But, you should catch this above.
if you need more help, let me know and we will get you taken care of.
P.S. For those attempting to help, he has a 2002-early 2004 car.
Old Jan 5, 2013 | 04:11 AM
pab18's Avatar
thanks thermo
will try all u said you a true decent bloke paul
Old Jan 5, 2013 | 04:40 AM
pab18's Avatar
p s my jag is right hand drive so would the sounder be under the driver side dsah thanks paul
Old Jan 5, 2013 | 06:12 AM
Thermo's Avatar
Veteran: Navy
pab18, from the diagrams that I have, there is no variation between LHD and RHD vehicles for the location of the sounder. So, it should be as I described.
Old Jan 5, 2013 | 12:59 PM
pab18's Avatar
hi chris thank you very much for your advice it was the sounder unit and it was located inside front right hand side as u look at car wheel arch by fog light has you said
if i could buy you a drink i would all the best and thanks for your help paul and thanks to any one else and gave advice
Old Jan 5, 2013 | 08:36 PM
Thermo's Avatar
Veteran: Navy
pab, not a problem. That is why we are here. Get the kitty purring again and enjoy the kitty.
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
sdelliott58
Sep 28, 2015 11:21 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
