Headlight - Disassembly
Old Aug 30, 2012 | 12:10 PM
Lcgi's Avatar
Arrow Headlight - Disassembly
Hello,
I have an unsightly and annoying water stain on the inside of the high beam front lens ?
Has anyone developed a method to remove & replace the front clear lens from the main body of the X-Type headlight assembly...?
It appears to be held together by two plastic clips and a mastic sealant (similar to material used to seal windscreen)
All help appreciated....
Old Aug 30, 2012 | 12:58 PM
jagger's Avatar
I had to take one of my headlights appart to repair the adjusters.
I wrote up the process and included pictures. Have a look at
this thread;
https://www.jaguarforums.com/forum/x...t-issue-72601/
My posting starts a little way down.
Old Aug 30, 2012 | 07:33 PM
Lcgi's Avatar
Arrow
Hi Jagger,
Thank you for the reminder and marker to your previous work.... which I had also interacted with at that time. I was kinda hoping that maybe someone had perfected the lens separation - hence my post of this thread.
Do you think use of a heat-gun would help with the release and softening of the Mastic ?
Old Aug 31, 2012 | 08:02 AM
jagger's Avatar
The adhesive used, which I believe is buytl rubber, has a slow give under
pressure. You should lift the snaps and put thin metal under them
to prevent them from re-engaging. Then slowly pry the two halves
appart with screw drivers. I used three at different places
about an inch apart. The buytl rubber will slowly stretch to where
you can reach in and cut it with a razor blade. Once you get one
end opened enough to cut the buytl you can work your way around.
The key is slow and steady.
Hope this helps,
Pete.
Old Aug 31, 2012 | 08:43 AM
Lcgi's Avatar
Thank you...... again.
Old Aug 31, 2012 | 10:05 PM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
Originally Posted by Exexpat
"...i've had about a dozen headlights apart and half of them require oven usage. I would bet this is the case with the x-type headlights also. You only need to heat the oven to about 250 degrees. Upon reassembly, you'll need to resoften the glue with a heat gun (but an oven shouldn't be necessary).
There's just something about putting parts of a Kitty in the oven that seem strange, but I did remember seeing Exexpat's post about this some time ago.
Just don't get caught!
Old Aug 31, 2012 | 10:09 PM
Lcgi's Avatar
Nope, I'll give the the Oven treatment..... A BIG MISS !!
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
sdelliott58
Sep 28, 2015 11:21 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
