headlights
Old Apr 27, 2014 | 03:52 PM
levi_mumba's Avatar
Default headlights
hey guys,
I need help, I changed the bulbs on my x type 2002 model with led bulbs 106SMD despite they were longer than the usual bulbs hence at the garage they removed the cap from the main headlamps to make them fit despite the light are just lighting 7meter and fog lights are gone too. can someone help
regards
Old Apr 27, 2014 | 11:53 PM
mikesmith2's Avatar
LED bulbs are not yet capable of replacing the dipped beam headlight as they do not project light.
That's probably why the distance is so poor.
I had the same issue when I put LED's in the front fogs of my XJ, looked better but no light
Old Apr 28, 2014 | 01:54 AM
levi_mumba's Avatar
Default lighting
thank you for the response,
what type of bulbs are advised to replace which can project to apart from the usual yellowish ones I had?
regards
Old Apr 28, 2014 | 01:07 PM
mikesmith2's Avatar
You can get Osram night breakers or there are other makes that give a whiter light output.
Best to shop around and see what are available, look on Ebay as several companies sell better bulbs for less money.
Old Apr 28, 2014 | 02:12 PM
billbjork's Avatar
I just replaced a dipped bulb on drivers side (US). Removed the battery and holder, wasn't hard. Took the bulb to Parts store, they didn't have a listing so they used a magnifying glass to match the number on the bulb to a standard mini bulb. works good, looks good.$5.50 for two.
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
sdelliott58
Sep 28, 2015 11:21 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
