Heater Control problem
Old Aug 16, 2015 | 04:20 AM
chrisyorkuk's Avatar
Default Heater Control problem
i have a 2.0 petrol 2001 model, the manual heater control panel isnt working only the fan control works on high speed. the air con buttons and heated rear window do not work and neither does the heater control as it blows hot air constantly. I did purchase a resisitor pack to fix this, but cannot find where to replace it, any help would be appreciated please, do i need to change anything else? I have already changed the heater controls panel but this didnt solve the problem. are there any diagrams that show location of resisitor pack?
Old Aug 16, 2015 | 03:59 PM
astromorg's Avatar
The resistor bank is next to the blower motor, behind the dash on the passenger side. Accessible from the footwell.
Have you checked fuses. Fuse 4, 30A in the engine compartment fuse box, F75, 7.5A and F80, 7.5A both in the glovebox fuse panel.
Old Aug 23, 2015 | 06:01 PM
hi thanks for this, resistor changed and fan working fine, the fuse in glovebox was gone, i changed it but it keeps blowing, i even put back the old heater control panel. any ideas?
Old Aug 23, 2015 | 07:42 PM
Dr dome's Avatar
Sounds like a hot wire touching ground. I would just start by tracing wires. Its a pain but you can find it. Its usually where the wires can be moved or touched.
afterburner1
Dec 16, 2015 12:12 AM
XJsc-guy
Sep 25, 2015 11:09 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
