Help
Old Mar 4, 2010 | 07:54 PM
Thermo's Avatar
Veteran: Navy
Boy, I am assuming you are talking about an 04 X-Type, not a 54 X-Type.
With that being said, first check fuse F35 in the passenger fuse box. If in doubt, swap the fuse with another 15 amp fuse from another circuit. If that doesn't help things, then it is very possible that you have lost the "Generic Electronics Module". That is the only thing that is common between all of these things other than the fuse.
