Help needed with fitting Navsat & Bluetooth
Old Nov 23, 2018 | 10:46 AM
rayclark1's Avatar
Default Help needed with fitting Navsat & Bluetooth
I am well into my new project of fitting out a none Factory fitted X Type 2003 with a SatNav & Bluetooth capability. - along with and new Android touch screen Head Unit.
However I am still wrestling with connections. I would welcome help from anyone who knows this job. The above diagram is where I think I am at the moment, with certain connections
issues. The diagram maybe incorrect, I have mocked this up as I have investigated the various aspects of this upgrade. Can anyone put me right based on the diagram and of course
any other information would be greatly appreciated.
Thanks in advance to those I have already had great info from.
Ray Clark
Old Nov 23, 2018 | 01:26 PM
dennis black's Avatar
take a picture of all the units and looms you have...its been a long time that i did this whole project to refresh my brain
Old Nov 24, 2018 | 11:45 AM
rayclark1's Avatar
Okay Dennis I will do so Tomorrow - hammering it down here and cannot get to my workshop.
Thank you for your interest.
regards
Ray
Old Nov 25, 2018 | 10:39 AM
rayclark1's Avatar
Dennis,
It would easier to send the pics via email - if you let have your address I will send that way. Otherwise I will send via the Forum. I am still awaiting my droid modified head unit back which will show all the leads and potential connections. Once I have all I will send on to you. Thanks once again- Ray
Old Nov 25, 2018 | 05:20 PM
via forum
Old Dec 1, 2018 | 02:29 AM
rayclark1's Avatar
Dennis please see the pictures relating to all components that are to be installed in my X type
regards
Ray
Old Dec 1, 2018 | 03:24 AM
rayclark1's Avatar
Dennis see revised diagram as I now see it. This after a little more contemplation & investigation.
Old Dec 1, 2018 | 05:37 PM
you will need one of these bluetooth modules whitch plugs into your harness in the link below
https://www.ebay.co.uk/p/Jaguar-X-Ty...-ae/2284315022
plugs here
by looking at your trunk you have the phone line already installed , the othe end is under the armrest plug the the btum under there then you need the silver box module for the trunk, also theres a voice module box
Old Dec 2, 2018 | 12:22 AM
rayclark1's Avatar
Hi Dennis
I do have the silver blue tooth module under the Sat Nav CD unit and also the BTUM box they should be among the pics I sent.
So basically two points
Is the installed telephone loom the right one for bluetooth as my vehicle was produced prior to this technology as far as I am aware.
I purchased two more updated looms that one of them apparently need installing to replace the non-bluetooth one already in-car.
The other is that I need to remove the arm rest and see what connector is under there to connect the BTUM box into.
Is that how you see it ?
regards
Old Dec 2, 2018 | 02:02 AM
rayclark1's Avatar
Dennis
I attach the pics you mentioned (BTUM & silver Bluetooth Modules)
Also re : the microphone issue, I attach the inside of my overhead console - I cannot see where the connection is.
As I said no small wire is anywhere up there.
Old Dec 2, 2018 | 12:42 PM
Dell Gailey's Avatar
He has the #3 (per Dr. Dome) type of overhead console connection. Completely different than the main 2 others.
Old Dec 2, 2018 | 11:52 PM
rayclark1's Avatar
So is it just a matter of refitting with a different or additional module ?
Old Dec 3, 2018 | 08:52 PM
you need this console of ebay for your mic to work
https://www.ebay.com/itm/JAGUAR-X-TY...tYPN:rk:6:pf:0
once you lift your armrest up you will see the plug
then plug this in
Old Dec 3, 2018 | 11:17 PM
rayclark1's Avatar
Hi Dennis
Yes I found this plug yesterday and fitted the BTUM module. Could I ask - The optical cable, one is already installed into the car
is this enough ? or do I have put a second line in to make a loop ? or indeed is it enough to just loop a 3 way at the Navsat boot end ?
I also found under the seat the blue connector for the Navsat loom I installed - there was a small grey one which I am assuming is
the antenna connector.
regards
Old Dec 4, 2018 | 01:43 AM
rayclark1's Avatar
Dennis, Please see the latest diagram revision of my project. I am slowly getting there but still need to
know if I do need to install any more optical cabling than I already have as you noticed from photograph
in the boot area. If not then I assume the loop system is put into place by the 3 way optical lead in boot
area between the Satnav & bluetooth silver module.
Old Dec 4, 2018 | 11:58 AM
yes you have to add a 5 or 4 link optical to it
like this dont worry if you plug this up and its not in order it will work ...15 years ago i went through the trial and error of doing this that is my cheezy original diagram....if you buy it of ebay its already labeled for each item,or you can do what i did and make one
heres a few
https://www.ebay.ie/sch/Vehicle-Parts-Accessories/131090/i.html?_sop=1&_nkw=x+type+jaguar+fibre+optic+lead
Old Dec 4, 2018 | 03:41 PM
rayclark1's Avatar
So in my case because I do not have the voice module, the amp, the CD changer I
will only need a loop 3 way optical cable in the boot area between the Satnav & telephone ?
Old Dec 4, 2018 | 07:02 PM
correct
Old Dec 5, 2018 | 02:31 PM
is that loom for the head unit a made up one or is it from another car ,if its from another car
Old Dec 5, 2018 | 04:23 PM
rayclark1's Avatar
Dennis
If you mean 1A43-10E925-BL I did get this from another vehicle
