HELP Please!
Old Mar 8, 2008 | 07:56 PM
FactoryJaguarTech's Avatar
Default RE: HELP Please!
Locks stopped from remote or from key in door? Do you get error beep when you try to lock?
Door ajar light is probably the latch, if none of the above, probably reason for lock issue also.
Old Mar 9, 2008 | 02:01 PM
When you take key out of ignition does it still chime? This would prevent the remote working to lock and unlock doors. If it chimes, put key back in and wiggle it out so the flap closes. If it works try spraying some wd40 in there. This would also indicate you have two different problems. Right rear door latch and ignition tumbler.
