Help Weird door lock problem
Old Feb 7, 2010 | 11:38 AM
Real_Tech's Avatar
Default Sounds like dead locking
Non U.S. spec cars have dead locking latches. The dead locking feature can be defeated by having the car programmed at the dealer with the IDS and disabling dead locking. If you are in the U.S. it is possible that dead locking has been programmed but without dead locking latches installed you should still be able to open the doors from the inside with just a pull of the handle. Were the handles stiff before the problem got to where you couldn't unlock door? May just need lube. Common problem.
Old Nov 11, 2010 | 06:07 PM
maxazor's Avatar
Anyone know what the issue is: We found the "problem door". We can lock and unlock all doors manually, but FOB lock will fail if the passenger door is not recognized as "locked"
Thermo, please PM me
Old Mar 17, 2011 | 10:31 AM
Glendoramike's Avatar
First thing to do is check your grounds. They are located at the bottom of the "A" pillers (front part of doorway, part of body not door). Bad grounds can make things real screwy. Clean them up as needed. Look for broken or almost broken wires. You may also have a problem with the GENERAL ELECTRONIC CONTROL MODULE. The CD JITS will show you where it is.
Old Jul 5, 2011 | 08:39 AM
pab's Avatar
pab
I just started experiencing a weird problem over the weekend regarding my locks. One of the rear doors won't lock unless I push the lock lever in
by hand. It will unlock electronically but not lock. It seems that the lock lever
is somehow hanging up and the electronic motor in the door can't pull it
shut.
I looked at the lock lever and the door handle but don't see any interference. The door is rarely used so I don't think it got banged in any way.
Hate to have to pull the door panel off to see what's happening...
Jaguar - it's not an automobile, it's a Motorcar
Old Apr 25, 2016 | 05:59 PM
rocket11's Avatar
Default Weird door lock problem
I can think of only one thing... when you are in drive the locks won't unlock, a safety implementation I guess. So, when you put the car in Park, the locks can then be used to lock or unlock the doors. That said... It may be possible that your linkage or shifter safety switch is not being engaged, or disengaged, whichever the case may be. So try holding the gear shifter up towards the dashboard while you unlock the door. its only an outside chance, but you never know.
Old Jan 31, 2017 | 03:08 AM
  #28
torgeirsolem's Avatar
I too have a similar problem. But the rear doors are not affected at all. Only the two front doors. It used to be only the driver door, but the last month or so, the passenger door started to have the same issue At first, when I opened the doors with the fob you could close and open the passenger door with the doorhandle but now it wont to that either.
If I open and close the doors with the fob lots of time it suddenly works, but only for a minute then it is back to only the fob will open the doors again.
Old Jan 31, 2017 | 06:40 AM
rocket11's Avatar
This may be a dumb question /suggestion, but, did you change the fob battery to eliminate that as a possibility?
Old Jan 31, 2017 | 11:33 AM
  #30
Default Its not the fob
I have tried with both my fobs, it's not the fob. It is when I try to open the doors from inside with the doorhandle. I just can't open them.
Old Jan 31, 2017 | 04:06 PM
  #31
rocket11's Avatar
Oh, in that case its in the door itself. Take the door panel off and look inside while you try to open the door to see whats happening, or, not happening, as the case may be.
Old Jan 31, 2017 | 04:07 PM
  #32
rocket11's Avatar
My drivers door almost cant be unlocked with the key snymore, really stiff now, and my fob stopped working a while ago, so i just dont ever lock it, lol
99xk8guy
Sep 29, 2025 10:51 PM
XJsc-guy
Nov 23, 2015 01:56 PM
jdzubas
Oct 4, 2015 09:14 AM
obwoodie
Sep 3, 2015 07:45 PM
dcvickers
Sep 2, 2015 06:14 PM
