HID Lights Conversion
Old Feb 20, 2007 | 04:43 PM
ruslan35's Avatar
Default RE: HID Lights Conversion
I installed one of HID converters on my 02' X-type. Make sure you get H1 bulbs with your kit!!! I tried different bulbs before, tried to modify housing for them, but they were siiting loose and after a while it wasn't operational. I ended up buying new housing for both sides!!!
Converters (black boxes) fit right under the housing (have to take off bumber cover and housings out) Drilled a few holes in the body and fit perfectly. Also had to make a hole in housing cover to fit a wire in there.
As far as i know there is only H1 housings availble. And for being OEM i wouldn't give much weight to that. I bought this after market conversion kit and it is brighter than OEM on Jaguar.
Old Feb 24, 2007 | 08:50 PM
aquill1's Avatar
Post some pics 35!
Old Feb 25, 2007 | 03:17 AM
04Xtype's Avatar
Hey Ohnoesaz,
How hard is it to install the hid kit, and how much did you pay for it?
Old Mar 2, 2007 | 10:00 PM
aquill1's Avatar
Thanks for the info guys, but,
When is someone going to man-up and take some pics of this project for those who are asking?[sm=ttiwwp.gif]
Old Mar 2, 2007 | 11:31 PM
Good question Aquill..........was wonderin that myself.
I'm sure either Nineball or IronCobra posted some pics on another thread a little while ago showing the HID effect and light emitted.
The Sportzblue bulbs I have in mine give off exactly the same bluish outline too.
Jim C
Old Mar 2, 2007 | 11:44 PM
IronCobra's Avatar
Wow, he did it the hard way. I simply used nylon spacers on the driver side and 2 screws on the driver side and slid the ballast and the mount under the passanger headlight and secured it with 2 screws.
You need a long tip for your drill though. I have pictures I'll post soon.
Old Mar 2, 2007 | 11:58 PM
IronCobra's Avatar
here are a couple pictures.
[IMG]local://upfiles/819/01CEB2CFAAD94AF0A3AEEA721E67F610.jpg[/IMG]
[IMG]local://upfiles/819/4176F207832B404182CD0BBB55E9A65E.jpg[/IMG]
Old Mar 3, 2007 | 12:10 AM
Cool.........thanks Cobra, that outta relieve the tension for a while.
Looks like a nice job by the way
JC
Old Mar 3, 2007 | 03:32 AM
IronCobra's Avatar
ORIGINAL: ohnoesaz
I paid $100 off ebay.
Its a simple install, but takes a long time since you want to do it perfect with no mistakes. And don't want to break bulbs.
I'll take pics tomorrow of it turned on and all that
btw I unplugged the dim marker lights on the inside housing since those were ugly sitting next to HID lights
Did you use a relayed harness with fuses and run powerdirectly from thebattery? or did you simpy tap into your factory wires?
Old Mar 4, 2007 | 02:59 PM
aquill1's Avatar
Hey there cobra thanks for the pics help those that were wondering, thats the way I plan on doing it if I ever get them which I've been thinking about since I've gotten the car (wife has been noticing the diff. between halogens and the hids lately so that should help!) did you run yours off the battery or from the harness? I always thought they had special connectors to accept the h1 harness as well as the shape of the bulb to fit into the bulb spot?
Mugatu
22
Jun 23, 2020 01:50 PM
redrover41
23
Sep 25, 2015 01:33 PM
afterburner1
General Tech Help
Sep 7, 2015 08:43 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
sklimii
Sep 5, 2015 06:04 AM
