HID question
Old Sep 27, 2008 | 04:52 PM
alarsen77's Avatar
Default HID question
Hi guys i have an 05 X-Type that didn't come with the HID's. I am wanting to put an HID kit in the car but have been doing some research about them and there are a few places saying that unless the headlamp assembly was meant for an HID kit it won't be that much of a benefit and will not be aimed and cut off properly. I was wondering what the thoughts are on this forum as to the halogen headlamp assembly and the H1 HID kits. Is it worth it?, should i just buy bright halogen bulbs? I am wanting an HID setup but i don't want to spend $200+ on something that isn't going to be that much better than the stock halogens and also not be working properly cause of the headlamp assembly not projecting it right.
Old Sep 27, 2008 | 05:11 PM
racerx82's Avatar
Default RE: HID question
Whats wrong with the current setup?
Old Sep 27, 2008 | 05:30 PM
alarsen77's Avatar
With the Halogen setup? I want better visibility at night. The halogen bulbs just don't seem that bright and the next alternative seems to be an HID kit.
Old Sep 27, 2008 | 05:51 PM
310jag's Avatar
Compared to even the lowest quality eBay HID setup, halogens suck. That's what's wrong with the current set up.
Aftermarket HID kits work great on any X-type that didn't come with them from the factory. Check the FAQ for several threads, including great pictorial walkthroughs of the install process (provided by me. [sm=smiley4.gif] )
Old Sep 27, 2008 | 06:16 PM
alarsen77's Avatar
So the HID kits work fine in the halogen headlamp assembly? Like i said i have read that they aren't focused right and will be very bright right in front of the car but as far as out in the distance they say that an OEM HID does a better job at distance.
Old Sep 27, 2008 | 08:19 PM
Size:  6.3 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Size:  9.9 KBName:  tshirt03-2.jpg
Hey Al.................check it out
https://www.jaguarforums.com/m_25544/tm.htm
Jim
Old Sep 27, 2008 | 08:22 PM
racerx82's Avatar
Jimbo comes through AGAIN! Who da man!
Old Sep 27, 2008 | 09:12 PM
alarsen77's Avatar
i will take a look through those thanks
Old Sep 27, 2008 | 09:17 PM
Lol...racer
Good luck Al.............lets know how you go bud
Jim
Old Sep 27, 2008 | 09:59 PM
jvegas's Avatar
the reason you read that the HID's don't look right in cars that are not designed with them is because those cars do not have projection lenses. The X-type has projection lenses! that means you will have a cut off line and they will look great! see my picture below, i have Hid headlights and Fog lights which I installed with a conversion kit... i think they look good how about you?
Old Sep 28, 2008 | 12:03 AM
alarsen77's Avatar
They do look great. Can i ask what bulbs you are using for the running lights? Are they LED? Which bulb and where did you get them? Were they plug and play? Also which HID kit did you use?
Old Sep 28, 2008 | 09:28 AM
jvegas's Avatar
i am using 194 white leds. i got them from v-leds.com. yes they were plug and play. for the hid's i used a kit from a seller on ebay. they are 6k in color.
Old Sep 28, 2008 | 11:48 AM
alarsen77's Avatar
Thanks for the reply. Which LED bulb specifically though i see they have like 8-10 different bulbs that are 194 under white LED's. Sorry to be pesky but i really like the look of your lights and would like to get the same bulb do you still have the part number? Also what bulbs are you using for your fogs?
Alex
redrover41
23
Sep 25, 2015 01:33 PM
VRB
Sep 15, 2015 08:18 AM
DustysSon
Sep 13, 2015 04:17 AM
afterburner1
General Tech Help
Sep 7, 2015 08:43 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
