How do i press the hub into the knuckle?
Old Nov 11, 2010 | 06:47 PM
Gergs's Avatar
Default How do i press the hub into the knuckle?
Doing a front right bearing change, 02 xtype 2.5.
How do i get the hub back into the knuckle all the way?
Old Nov 23, 2010 | 09:08 AM
lightninfil's Avatar
alot of times when you dont have the special tools you can use part of the old bearing. you need to support the inside of the new bearing with the old bearing, that way when your pressing the hub in you dont separate the bearing you just installed. just food for thought you could take you knuckle off the vehicle and let a shop do the actual pressing of the new bearing in. my guess is they would charge around an hour worth of labor. hope this helped.
TreVoRTasmin
Feb 23, 2021 03:13 PM
Dave1109971
Dec 15, 2015 06:16 PM
SCMike
Nov 25, 2015 07:55 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
