how to fix broken headlights
Old Mar 30, 2008 | 04:38 PM
jvegas's Avatar
Default how to fix broken headlights
I have a problem that most of you have. My headlights bounce around and won’t adjust with the leveling screws. Well this past week I bought a broken headlight with the same problem mine has for experimental purposes. Long story short. I now have a non-bouncing and adjustable headlight! Here is what I did; the reason the inner housing was moving around was because there are only 2 little pieces of plastic and a little “shelf” holding the inside of the light to the outside. I used a product called JB Weld (can be found at any hardware store) and carefully aligned the first piece of plastic on the low beam side. I them layered the welding on the plastic piece. I let the light sit upside down over night to keep pressure on the plastic tab. The next day I flipped the light over and it seemed to hold. Next I did the same thing to the high beam side. Two days later I coated the same parts with more welding paste. Today I tested the light by tuning the adjustment screw….. And it worked! I am going to use more weld on the two joints and then install the light into my car. Below are some pictures of the finished product. Honestly I did not think this would work so I took no before pics. One thing to remember for those of you that will fix your headlights, they have to remain out of the car for around3-5 days for the weld to cure properly so make sure you have another car to drive or buy broke headlights and then just swap them when they are fixed.
Old Mar 30, 2008 | 05:31 PM
FactoryJaguarTech's Avatar
Default RE: how to fix broken headlights
I want to know what magazine that is the light is resting on?
Old Mar 30, 2008 | 05:36 PM
Dennis's Avatar
ud
Old Mar 30, 2008 | 05:43 PM
It is a good fix. This is for non-Hid lights.
Old Mar 30, 2008 | 05:47 PM
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Looks like Mayfair or Men only as far as I can see
Nice one vegas......lol
Seems like there's a few copies too
Nice one on the fix as it seems to work......could help out a few members that've had that problem
Jim
Old Mar 30, 2008 | 06:22 PM
jvegas's Avatar
it's on a glass table and the magazine is under the glass. it is "Money" magazine. and yes for non-HID lights. but mine has the HID conversion kit in it.
Old Mar 30, 2008 | 09:03 PM
HID conversion is different from factory HID. This fix will not work on the HID lamps. Only on Halogen assembley.
Old Mar 30, 2008 | 09:47 PM
jvegas's Avatar
ORIGINAL: FactoryJaguarTech
right. i just don't want people thinking i am rolling around with those ugly azz halogen lights. LOL
Old Mar 31, 2008 | 05:00 AM
Lol
Old Jun 20, 2009 | 03:26 PM
patrick12's Avatar
i have xenon light and all white plastic holder are broken, is it not possible to buy only the holder?
Old Jun 20, 2009 | 11:11 PM
Disco stu55's Avatar
thats why im wondering if i should do the hid swap or not?
99xk8guy
May 28, 2024 09:36 PM
Kylejones
Sep 13, 2015 04:36 AM
avern1
Sep 8, 2015 06:25 PM
sklimii
Sep 5, 2015 06:04 AM
laserguy
Sep 3, 2015 02:02 PM
