How to fix Security failed for a 2003 xtype 3.0?
Old Jul 21, 2019 | 05:13 AM
Mike-Ko's Avatar
Default How to fix Security failed for a 2003 xtype 3.0?
How to fix the security failed on the xtype?
the dealer is around 70km away, the car won’t start.
i replace the battery and fob , reprogrammed the key and it still shows security failed.
Old Jul 21, 2019 | 11:54 AM
x_type_lpg's Avatar
you need to use the sdd software and select a fault on the ip cluster, then select fit new ip cluster. you will need two keys with the transponder The sdd option for keyfob transmitter is for programing the four button part of the fob.
Lorraine Burke
Oct 6, 2016 10:31 AM
Iain Yates
Sep 16, 2015 06:48 PM
racerx82
Sep 13, 2015 06:26 AM
websun
Oct 5, 2011 12:10 PM
Dec 21, 2005 10:53 PM
