How many rear O2 sensors
Old Aug 1, 2017 | 12:21 AM
CHarper's Avatar
Default How many rear O2 sensors
I had both of my catalytic converters replaced on my x type 2002. Do I need to order 1 or 2 rear oxygen sensors? How many for the front?
Old Aug 1, 2017 | 02:13 AM
Dell Gailey's Avatar
Front sensor =
Rear sensor =
Old Aug 1, 2017 | 04:48 PM
CHarper's Avatar
Thank you, but I need to know how many. It looks to me that there are 2 O2 sensors at rear and 2 to 3 up front.
Old Aug 1, 2017 | 04:58 PM
Alfadude's Avatar
There are two upper sensors and two lower sensors; a pair for each bank. Four total sensors.
Old Aug 1, 2017 | 06:14 PM
CHarper's Avatar
Thank you. I have found that ordering the parts online makes it far less expensive when brought to my mechanic. I read here that Bosche parts don't neccessarily always work, is that true?
The fault codes I received after having the catalytic converters were replaced are. P0420 and P0430.
Old Aug 1, 2017 | 06:35 PM
dwclapp's Avatar
Dittos to Alfadude.
The pictures in this post show the locations of all 4 oxygen sensors: https://www.jaguarforums.com/forum/x...4/#post1084601
And the pictures in the preceding post show the locations of all 4 electrical connectors to the 4 oxygen sensors:
https://www.jaguarforums.com/forum/x...4/#post1084230
Bosch, Denso and NGK oxygen sensors all work. Both upstream sensors are the same, and both downstream sensors are the same, but the upstream and downstream sensors are different (because upstream sensors are used to fine tune the air / fuel ratio, and downstream sensors monitor the health of the catalytic converters).
Old Aug 1, 2017 | 07:31 PM
CHarper's Avatar
You are all wonderful and prompt. Many many thanks.
JimC64
Sep 22, 2025 02:52 PM
webshark
Jun 20, 2020 07:59 PM
Jrp79
Apr 20, 2017 09:46 PM
twopumpchump
Dec 8, 2016 08:21 AM
racerx82
Jul 18, 2007 09:50 PM
