How to read codes via climate panel?
Old May 15, 2021 | 05:05 PM
catfondler's Avatar
Default How to read codes via climate panel?
Hey guys!
Does anybody know how to read climate control system error codes via the climate panel?
Recirculation + Auto doesn't work. There is a graphical LCDisplay, not a small LCD line..
Thanks, catfondler
Old May 15, 2021 | 06:22 PM
Thermo's Avatar
Veteran: Navy
catfondler, the only way I know to read those codes is to get a higher end scanner like an SDD system. That will let you probe into that module and see what codes are in it. I am not aware of any way to do specifically what you are after. If you have the Nav/AC/heat setup, then you can try holding down the return (or is it the valet) button for like 15 seconds and this will put the radio into a diagnostic area and then maybe you can find what you are after that way. BUt, it is sounding like you have the separate radio and A/C controls. Not sure how to do that with that module.
Old May 15, 2021 | 07:41 PM
catfondler's Avatar
Hi Thermo!
I've no knowledge about X-Type climate / radio / navigation control panels.
At my 2006 X-Type 2.5 L AWD, sedan it looks like that on this photo:
(Climate Control Moduls of other models [e.g. S-Type] with simpler and older LCDisplay are cabable of self test mode. Also different Ford control panels.)
My available diag systems are not able to read the CCM (and TCM). I don't know if it's due to restrictions or a cars failure.
Cheers, catfondler
Old May 16, 2021 | 07:18 AM
Thermo's Avatar
Veteran: Navy
catfondler, you have the separate A/C and radio modules. I am not aware of any way to get the A/C module (aka, ACCM) to give you codes. You may want to look on say Youtube, but most of what I remember seeing was for the Nav/Radio/AC unit that fits in that whole center console area.
Old May 16, 2021 | 10:09 AM
catfondler's Avatar
Thermo, thanks for your reply.
Of course i didn't found anything about my setup with separate A/C and radio module until now..
catfondler
Old May 16, 2021 | 06:50 PM
Thermo's Avatar
Veteran: Navy
catfondler, if this helps put your mind at ease any, the climate module is known as a failure point with your setup. So, if you are having issues with that panel, I would be looking to get my hands on a new one and call it good.
Old May 16, 2021 | 09:46 PM
catfondler's Avatar
Hi Thermo!
Meanwhile I'd found a climate control systems training course for XJ/XK, S-Type, and X-Type.
Only XJ/XK seem to have an integrated self-test.
But my problem is solved: a defective transmission fluid temperature sensor. (A/C didn't had a failure.)
Cheers, catfondler
Mirco Petroni
Aug 25, 2020 08:26 AM
JayW
Sep 7, 2016 03:45 AM
aquifer
Jun 25, 2016 03:42 PM
