I have a 2003 x-type... i need some xenon blubs
Old Aug 20, 2007 | 03:52 PM
Default RE: I have a 2003 x-type... i need some xenon blubs
try Ebay.....always a good source
Or www.performancebulbs.co.uk
Jim
Old Aug 20, 2007 | 04:52 PM
Cadillac's Avatar
6000K is more than enough ,keep mind most factory Xenons are 4500K
Old Aug 20, 2007 | 08:29 PM
H20boy's Avatar
All projector HIDs are the D2S variety. A D2R applies to reflector-type headlamps like the Escalades, Lexus models, etc.
I have had OSRAM type and Phillips...both are quality bulbs. Osrams have just a slight more purple tint to it then the Phillips. You can't go wrong with either one. Ebay is where I would go also.
I mentioned this on the xk8 thread
https://www.jaguarforums.com/m_20869/mpage_1/key_/tm.htm#20869 as well, but 8000k will kill your illumination distance considerably. It may look bluer, but it makes the road harder to see, relfectors and signs are less bright, etc. 5000k are perfect, 6000k would be the highest I would go personally. Trust me, if you want oncoming cars and others to see the blue/purple when you approach, you will achieve it with the cutoff shield in the projector. (and I presume it has one if it is truly an HID headlamp). See the pics in my other thread, and good luck in your project. The result really good when you are finished.
__________________
Hey mods, what's up with my link...i've put it in 4x and it won't work???
Old Nov 13, 2007 | 09:32 PM
AGLXTYPE's Avatar
H20boy,
I see that you have (2) JL Audio 6w0 subs listed. Can you tell me how much power you are running to them? What kind of sound, output, sq can you elaborate on? Can you feel the subs as well as hear them? Do they give enough output to be heard a 1/4 to 1/2 a block away? Can't expect chest pounding from a 6.5" sub. Not sure what kind of music you listen to but I'm a R&B, Classic Rock, Hip Hop fan and I'm looking to install (2) 6w0's in my X-Type on the rear deck in the factory sub box and Polk DB6500 components in all four doors.
Thanks,
Nate
Msteiner
May 16, 2016 12:19 AM
jospolice
Oct 2, 2015 07:16 PM
jospolice
Oct 1, 2015 07:52 AM
apolloxk8
Sep 28, 2015 08:27 PM
SoCalJagS
Sep 27, 2015 09:20 AM
