Injector rattle
Old 09-30-2015, 11:57 AM
jospolice's Avatar
Default Injector rattle
2003 Jag X-type 2.5l 5 speed manual AWD. When key is turned on there is a ticking noise. Upon starting engine, emits ticking sounds again for a second and stops. Was told this is due to injector building pressure & when started rebuilding pressure in injector rail. Is this an indication that the system is about to fail, or just annoying noise to the OCD owner ?
Old 09-30-2015, 03:11 PM
GGG is offline
Received 16,823 Likes on 12,178 Posts
Welcome to the forum jospolice,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
jospolice (09-30-2015)
Old 09-30-2015, 08:23 PM
mrplow58's Avatar
Try finding a place, that pressure cleans the injector system, or run a few cans of injector cleaner yourself.
I put a whole can in, when I have about a quarter tank, and then a full can when I fill up the tank a couple of times thereafter.
What it sounds like, is that you may have an injector leaking down, and this is usually caused by not changing the fuel filter enough. Most filters have a bypass internally, so the car will still run.
The fuel system cleaner cans are the cheapest way to go, and if necessary locate the injector that is clicking, and change it out......My 2 cents.......Mike
Old 09-30-2015, 10:23 PM
jospolice's Avatar
Default Injector noise
Thanks Mike,
I put a half can of Seafoam in the tank which was half full. I will put a full can in before I add gas. I will check to have the injectors cleaned if that doesn't work.
Old 10-02-2015, 07:16 PM
jospolice's Avatar
Thanks again Mike,
I followed your advise about putting injector cleaner in the fuel tank & it worked. It quieted it down after about twenty miles. It runs noticeably better. I am going to be replacing the fuel filter too.
redxk8
10-04-2015 08:28 AM
inactualis
10-02-2015 11:13 AM
millertic
09-30-2015 08:11 PM
SD96XJ6L
09-25-2015 10:53 PM
Quick Reply: Injector rattle
