Intermittant ABS light.
Old Feb 16, 2014 | 09:32 AM
Royston's Avatar
Default Intermittant ABS light.
My ABS light sometimes comes on when I start. However the next day it doesn't, then maybe a day or two later does it again. This was happening before I had the front discs and pads replaced last week as they needed doing anyway, and the light stayed off for a couple of days and then came back on today when I restarted it after going to a shop. The brakes feel normal - any ideas why it should be intermittent instead of either on or off?
Old Feb 16, 2014 | 09:57 AM
bracester's Avatar
Have you checked the fluid level underneath the hood?
Old Feb 16, 2014 | 10:23 AM
Royston's Avatar
Just checked it and it was at the right level.
Old Feb 16, 2014 | 10:27 AM
car5car's Avatar
The most common problem of ABS system is broken sensor wire. Visually inspect wires (turn wheels right then left)
If you don't see anything, go to repair shop to read ABS codes, some cars blink codes.
bdboyle
Sep 16, 2019 05:58 PM
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
leep123
Sep 30, 2015 03:41 PM
