Intermittent CEL P0174, P0332, P1341
Old Jun 12, 2025 | 10:00 PM
Mizah87's Avatar
Default Intermittent CEL P0174, P0332, P1341
2002 x-type 3.0L
Seems to run fine, I've been jumping through fixing several issues. Replaced a dead alternator, then replaced the ABS module to fix the ABS light. Then I got a P0174 light, I did a quick check for vacuum leaks and used some liquid gasket to help with any possible areas. Reset the codes.
After that I got the Cruise Control not available light flashing intermittently, the light turned off. After parking and turning the car off/on, the CEL came on with P0332 error. I reset the codes, drove fine for a few days. Today I got a P1341 code. Reset it and also driving fine for now.
I have noticed (maybe in my head) that when the car takes an extra second or two turn over, that's when I know there's a code coming.
Thoughts?
Old Jun 13, 2025 | 12:20 PM
Blues boy's Avatar
Get your battery checked. The X type is notorious for throwing up codes if the battery is below par. Especially as you say that it seems to happen when it's needed longer turning over.
Old Jun 13, 2025 | 04:03 PM
Mizah87's Avatar
Battery is only 2 years old. I'll go get it checked to be certain.
Old Jun 15, 2025 | 04:05 PM
Mizah87's Avatar
Battery and alternator check were both good. Today I had the P0174 light come back on. O'rielly OBD report recommended replacing intake manifold runner control valve vacuum hose.
Old Jun 17, 2025 | 04:50 AM
JagV8's Avatar
Don't do that until you read previous posts about the code(s) and fix(es). Check fuel trims.
Old Jun 17, 2025 | 01:34 PM
Mizah87's Avatar
Ya I read through the common leak locations, I'm going to do a smoke test to see what I can find. But I'm more concerned about the knock sensor and camshaft errors.
dh53
Mar 1, 2024 05:24 PM
bullitt149
Apr 23, 2021 07:26 PM
RollaJones
Sep 27, 2015 03:31 PM
rayclark1
May 21, 2014 11:07 AM
OldMike
Jul 22, 2013 07:22 PM
