Intermittent fault with headlights
Old Jun 2, 2009 | 03:31 PM
Stumpy1's Avatar
Default Intermittent fault with headlights
Hi i'm a newbie to the X type having recently purchased a 3.0 SE which I have to say I am very pleased with. I have noticed occasionally when turning the headlights on that the passenger side does'nt work but at the same time also the dial display lights do not come on either, however after various attempts it will eventually work ok. Does anybody know what might cause this ? Could it be a faulty switch or maybe a relay problem.
Old Jun 2, 2009 | 07:25 PM
Thermo's Avatar
Veteran: Navy
Stumpy, because the one headlight comes on, but the other one does not, that rules out the relay and anything upstream. So, this leaves fuse F17, the wiring between the fuse and headlight bulb, or the bulb itself. I would recommend switching fuses F16 and F17 and seeing if the problem moves over to the other side. If it does, then that confirms a bad fuse. If not, you will need to connect a multimeter to the green/white wire on the back side of the passenger side headlight. With the headlight not working, do you have 12 VDC on this wire? If yes, then you have a bad socket going to the headlight or a bad bulb. If no, then you have a wiring problem between the fuse box and the headlight assembly.
If you need more help, just hollar.
Old Jun 4, 2009 | 12:44 PM
Stumpy1's Avatar
Thanks Thermo. I'll try the fuse switch round to start with.
bdboyle
Sep 16, 2019 05:58 PM
GGabriel
Nov 22, 2018 03:53 AM
KarimPA
Sep 27, 2015 08:46 AM
kevinl
Sep 24, 2015 08:25 PM
John Fox
Sep 19, 2015 07:56 PM
