jag stalling when depressing clutch sometimes
Old Jun 28, 2013 | 05:48 AM
bharvey622's Avatar
Default jag stalling when depressing clutch sometimes
Hi my 02 xtype will stall every now and then.. For instance doing 40 mph... Traffic light turns yellow I depress clutch and hit the brakes... The car will die.. Its happens a few times.. Anyone have this issue?
Old Jun 28, 2013 | 01:15 PM
disguay's Avatar
Yes, I have had this issue. Not to the point that it will stall the car, but to the point it will put my car into limp mode. It is probably a vacuum leak. Check your brake booster hose that goes to the top of the intak manifold. There is a little plastic black and grey valve that corrodes and falls apart. Coat it in epoxy so it wont leak anymore and keep driving. I have had this fix done on my car for over 10k miles. Looks funky, but beats buying the new part for over $100
Old Jun 29, 2013 | 08:53 AM
bharvey622's Avatar
So I checked the hoses from the brake booster to the intake.. Everything seems good and tight.. Should I seal them anyways or could something else cause this
Old Jul 2, 2013 | 01:39 AM
disguay's Avatar
Ok, your clutch may actually be going bad... Take it to a parking lot, put it in first, depress the clutch and give it some gas and see if you go forward. If so, then your throw out bearing is shot.
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
Doovoe
Sep 8, 2015 05:42 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
MrMellor
Sep 7, 2015 10:22 AM
joseph1945
Sep 5, 2015 07:12 PM
