Jaguaer x type 2004 Manual
Old Apr 25, 2017 | 01:58 PM
JagJoe80's Avatar
Default Jaguaer x type 2004 Manual
Cant would not start called AA they jump started it and said bendix not engaging. Can I replace it myself or is it a garage job???
Joe
Old Apr 25, 2017 | 02:37 PM
JagV8's Avatar
Usually (if present) part of starter motor so ...
Old Apr 25, 2017 | 06:37 PM
JBzXJ40's Avatar
These are located on the top of the transmission, fairly easy to get out, don't need any special tools.
Old Apr 25, 2017 | 11:30 PM
avern1's Avatar
If all it took was a jump start then I wouldn't jump up and condemn the starter. There are a few basic thing you can do first and see if it solves your problem. Changing the starter is a straight forward DIY project.
1. I would get the battery load test and make sure it is fully charged.
2. Remove and clean the connectors on each end of the battery cables.
3. Check the positive cable for corrosion in the strands of the cable.
After these simple steps if you are still having start problems then go ahead and replace the starter.
