Jaguar 2002 3.0 x type
Old Oct 24, 2013 | 05:05 PM
juanita simmons's Avatar
Default Jaguar 2002 3.0 x type
I brought a set of new tires two years ago. I put 10, 000 miles on them.
I hit the curbe an ruined a tire. I brought a new tire with slightly
Different treads. Will that make a difference in getting a smoothe drive? I had all tires
All tires Alligned.
Help!!
Thank You.
Also is the navigation speaker connected to car speskers. It was ok until I had the speakers sound checked
I can hear the navigation voice clearly and sometimes I can't. the sound is faint.
Old Oct 24, 2013 | 07:01 PM
Juanita,
I've already moved one of your posts today from North East US forum to X-Type forum. Please post model-specific questions in the relevant tech forum.
Old Oct 24, 2013 | 07:44 PM
Thermo's Avatar
Veteran: Navy
juanita, as long as the other tires are not too worn, you should not have any issues. Granted, it tends to be better if you match the same tread wear on both tires on the same end (ie, both fronts, or both rears). As long as you are within say an 1/8" of tire diameter you should be fine. Just don't be mixing say a 225/45R17 and a 235/45R17 on the same car. It takes a lot of math to know what tires to mate with other tires when you start changing tread width so you don't screw up the transfer case.
stanjag
Dec 29, 2024 08:26 PM
montypeek
Sep 6, 2015 04:57 PM
roumor
Aug 28, 2015 01:02 PM
mkrion
Aug 26, 2015 11:43 AM
brent65622
Aug 26, 2015 08:41 AM
