Jaguar 2003 x-Type error codes P0171,P0174
Old Jan 20, 2012 | 04:14 PM
Chrys's Avatar
Exclamation Jaguar 2003 x-Type error codes P0171,P0174 Fixed!!
Hello evryone, and thanks for all the help.
H have these new codes and I would like your help again.
The codes are: P0171, and P0174
I also get,P0300, P0301,P0302,P0303,P0304,P0305,P0306,P!316
S.O.S Please this car is driving me crazy!!!!
Need to pass state inspection.
Thank u!!
Old Jan 20, 2012 | 10:05 PM
mohrd's Avatar
The 0171 and 0174 would lead you to think of vacuum leak and too much air but if you are also getting the random misfire and individual cylinder misfire codes (p0300, 0301, etc and the p1316) I'm thinking fuel delivery may be the problem. Clogged fuel filter, fuel injector circuit faults, or ECM. You need tech help. Unless you put some REALLY bad gas in there.
Old Jan 20, 2012 | 10:45 PM
joycesjag's Avatar
MAF sensor!
or a very bad vacuum leak
Old Jan 20, 2012 | 10:57 PM
mohrd's Avatar
Chrys, I just noticed that you had another post and that you were mucking about in the engine compartment BEFORE the 0300 codes showed up. Did you dislodge something and not get it hooked back up? Check any connections you could have loosened.
Old Jan 21, 2012 | 08:57 AM
Chrys's Avatar
Hello guys and thanks for your quick response.
Yes… I did post before with other 0300 errors Mohrd, but the r not there anymore.
I got this car 2 weeks ago with check engine light on.
First scan I got the P1647 error code. I followed the recommendations from the forum I changed the "bank 2 sensor 1"
And the Problem is fixed!! Thanks!!
(By the way, Auto zone sells it for $88... I paid online $126)
Then 2 new error codes came up: P0171 and P0174
I followed the recommendations from the forum again and check for vacuum leaks. I found the O rings leaking and replace them.
(By the way the bottom one is hard to remove the housing ...Someone recommend cutting the old ring and try to replace the new with out remove the housing. Don't do it! It will brake! What can you do is.. Use a screwdriver when sensor almost out and gentle force up and it will come out)
So I changed the O rings, the air filter, and the spark plugs. (this is not an easy job)
And then still I got the error codes:
P0171 and P0174
Plus: P0300, P0301, P0302, P0303, P0304,P0305,P0306,P316
The spark plugs cap was preset at: 0.40 is this the correct Cap?
So these are the steps so far...I thought it will run better not worse.
And yes I use premium gas so is not the gas.
Car runs rough when is cold ..Sounds like running on 3-4 cylinders. But when worm runs very well
Thanks again for all your help!
Old Jan 24, 2012 | 11:29 PM
Green Machine's Avatar
P0171 and P0174
Don't know why your o-ring broke sliding it over the lower IMT valve. It's a very easy operation to slip the new O-ring over one ear at a time. Prying the valve housing out of the manifold is much riskier and more costly if you slip and break the valve housing.
Old Jan 26, 2012 | 04:43 PM
Chrys's Avatar
I had enough with this car.. Can’t changing parts just to find out if that is the problem. I like to sell it! I paid $ 4800 for it.. I paid another $300 for parts...
I'll take $ 4000 for it. If anyone wants it. Please let me know and I can send photos.
Car has 137000 miles on it.
Thanks!!!
Old Jan 26, 2012 | 05:09 PM
iownme's Avatar
$4800 is pretty cheap, even for a car with some problems, I would expect to be doing some work on it to get it up to running order. Calm down and consider if you actually want the car if it can be made roadworthy.
If you do...you are already halfway there with the work you have done. If you can do all that you've done so far, then the rest is as straight forward.
BUT it does take time and many posts on these forums to get there. That is the price to pay if you want a super cheap X. If you love the X type and have money...sell your current one and go pay around $6-7000 to get an already roadworthy X.
OR...be prepared for lots of typing.
I have been in your position, with a broken new car and an inspection due, so my sympathies to you.
Good luck
Old Jan 27, 2012 | 08:59 AM
pab's Avatar
pab
Judging from where you are located I recommend you contact Samuels Jaguar Motors Ltd in Alston. They are an independent Jaguar repair shop and are highly regarded.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Feb 9, 2012 | 06:53 PM
Chrys's Avatar
Hello there guys, just a an update to my error codes P0171 and P0174
I have change the MAF and the gas filter.. and Yes the same error codes are still there.
There is nothing more to change or check I've done it all....
Your suggestions please, as I have had enough at this point.
Old Feb 12, 2012 | 09:52 AM
Jplsu1981's Avatar
I've been having similar problems, ONLY on cold mornings (rough idle, sputtering when at stop light or at a stop while braking). Same error codes. I was convinced it was either a vacuum leak or bad MAF sensor. Took it into the Jaguar dealership here in Baton Rouge... they told me they checked for vacuum leaks and found that the Intake Manifold Gasket had a vacuum leak. They are fixing that right now, and hopefully it will solve my cold morning issues. $450 fix. Other typical vacuum leaks are brake line booster hose, PCV hose, Orings
Old Feb 12, 2012 | 09:55 AM
Jplsu1981's Avatar
Originally Posted by HFet
when i start my 2003 jaguar x type in the morning, it shakes violently and starts to die with the check engine light flashing. what could cause this?? i do have error codes P0171, P0174, and P0300-P0306. are those related to this problem?
sounds like you've got a vacuum leak like me (check the brake line booster hose, Pcv hose, and Orings...also maybe the Intake Manifold Gasket).
Once your car warms up and/or you accelerate and get the RPMs up does your car drive fine?
My issues are only at idle...in park idle when first starting...Also when applying the brake at a stop light or stop sign while in drive my car tends to "sputter/bounce"
Old Feb 18, 2012 | 01:48 PM
Chrys's Avatar
Hello there guys, I've replased so Far:
Big o-rings, pvc hose, upper intake gaskets, Mass Air sensor, two small o-rings in the upper intake, Plugs, air filter.
And still getting: Fault Codes: P0171 and P0174
I have photos from my scan reader that I would like to upload..but I don't know how to..I think if someone can read the test results it may help others with same problems.
Thanks again for your help!
Old Feb 19, 2012 | 03:33 AM
kalacho2006's Avatar
Default codes
my Car has the same issue after replace all that parts only reset the codes, run my car like 50 miles and light never come back! Maybe some issue with your Ecu try it!
Old Feb 19, 2012 | 08:19 AM
Take a look here post #6.
Old Mar 2, 2012 | 04:43 PM
Chrys's Avatar
Hello there guys, this an update on my Fault Codes: P0171 and P0174
I replace the intake lower gaskets and problem is solved!!!!
However now I get error P0430
Anyone know anything about it?
Old Mar 2, 2012 | 04:59 PM
P0430 EMS
OBD II
Catalytic converter system
efficiency below threshold –
bank 2
Catalyst efficiency monitor
drive cycle – page 5
2 N None — HO2 Sensor disconnected
HO2 Sensor to ECM wiring fault
HO2 Sensor heater to ECM wiring fault
HO2 Sensor heater failure
Upstream HO2 Sensor failure
Downstream HO2 Sensor failure
Catalyst failure
Old Mar 5, 2015 | 10:34 PM
BloodBike's Avatar
Default P0171 and P0174
I wanted to say thanks guys. I have a 2005 Jaguar X-type. I had the same faults P0171 and P0174 and changed out the O-Ring, Air filter, Fuel filter, cleaned the MAF sensor and still no change. I then decided to change out the brake booster hose and sure enough, it had a nice size whole in the check valve (middle part). I replaced it and I'm waiting to see if the code clears. I was told it should clear on its on after I drive it around a couple of miles. Computer should reset itself. If it doesn't how do I clear the fault? I'm thinking the whole was pretty big and I don't think the MAF sensor needs to be replaced.
Old Mar 6, 2015 | 03:30 PM
jfenley's Avatar
Default Ran across this TB looking up DTCs
Technical Bulletin 2002 - 2006 Jaguar X Type
Sep 11, 2006
MODEL Jaguar X-TYPE
Engine Misfire or MIL Illumination with Possible DTCs Stored
AFFECTED VEHICLE RANGE:
X-TYPE VIN: C00001 to E99388
Model Year: 2002 to 2006
CONDITION SUMMARY:
ENGINE MISFIRE OR MIL ILLUMINATION WITH POSSIBLE DIAGNOSTIC TROUBLE CODES (DTC) STORED
Situation: A customer may report a concern of an engine misfire or MIL illumination. Excessive glue on ground strap may be the cause.
It is possible that one or more of the following DTCs have been stored: P0300, P0301 P0303, P0305, P0302, P0304, P0306, P1313, P1314, P1316, P0351, P0352, P0353, P0354 or P0356.
Action: Should a customer express a concern, refer to the Repair Procedure detailed in this bulletin to clean the ground strap and clear any stored DTCs.
PARTS: No parts required.
TOOLS: DS CD43 with Patch File 3 or later software installed or
IDS DVD101 or later software installed
NOTE :
Repair procedures are under constant review, and therefore times are subject to change; those quoted here must be taken as guidance only. Always refer to DDW to obtain the latest repair time.
DDW requires the use of causal part numbers. Labor only claims must show the causal part number with a quantity of zero.
Normal warranty policy and procedures apply.
REPAIR PROCEDURE
CLEAN GROUND STRAP AND CLEAR DTC
1. Open hood and install fender protectors.
2. Remove the ground strap bolt. (Figure 1)
3. Clean excessive glue from the ground strap.
4. Correctly seat the ground strap.
5. Install bolt to ground strap and tighten to 9Nm (6.5 lbf-ft).
CAUTION :Integrated Diagnostic System (IDS) CD43 Patch File 3 or DVD101 software or later must be used for this repair procedure.
A Midtronics PSC-550 Vehicle Power Supply must be connected to the vehicle battery during module configuration.
6. Connect the approved power supply to the vehicle battery.
7. Connect IDS to the vehicle and begin a new diagnostic session.
8. Enter the correct VIN for the current vehicle.
9. Follow the IDS prompts to read the vehicle configuration.
10. When prompted "Do you wish to read diagnostic trouble codes?", select "YES" and then press "tick" to continue.
11. Follow all on-screen instructions and clear any fault codes.
12. When the task is completed, exit the current session.
13. Disconnect IDS and the battery charger/power supply.
14. Remove fender protectors and close hood.
