Jaguar ODB2 scan tool help
Old Oct 28, 2010 | 08:21 PM
SEBZX79's Avatar
Default Jaguar ODB2 scan tool help
I am looking to purchase a scanner for our Jags but I am not sure which one. I want to be able to turn off lights not just read codes. So for I have found one that might be good but NOT sure if it will work with out Jags. It does work with Ford vehicles and I am thinking that the software might be close.
Please help I am looking to spend no more then 500 and would like to spend less if I can
http://www.amazon.com/Autel-AULMD801...4&sr=1-1-fkmr0
Old Oct 28, 2010 | 08:34 PM
Thermo's Avatar
Veteran: Navy
SEB, you can turn off lights with the cheapy $70 units. The trick is, will the code remain clear. Even with the higher end units, if the code reappears, the light is going to come back on. I would say to do one of 2 things unless you really need the higher end unit:
1) go to your local autoparts store and get a $70 unit and go with that. Clear all the codes and the light will go out. The only down side I see with a unit like this is the description of the code is normally fairly vague, so, you will normally end up looking the code up on the internet to get more info. I find myself doing this anyways to get an idea of the common failure items associated with the code.
2) if you look around, you can find cables along with computer programs that you can take your Palm Pilots or a laptop and then with the special cable, read all the codes you want and perform many functions that the $70 units can't do. These can be picked up for as little as $30 and normally for under $100. These will even normally allow you to see real time parameters of your car. But, this all assumes you have a laptop at your disposal.
Old Oct 28, 2010 | 08:46 PM
SEBZX79's Avatar
Thermo,
Will they allow me to truble shoot ABS, Airbag lights and so on? I want a tool that I can use a lot as I am a wholesaler and run into this all the time.
Any specific programs that you would recommend.?
benebob's Avatar
ud
I have this one and it does just what you're asking it to do on both my Jags.
http://cgi.ebay.com/ebaymotors/CAN-B...item2c58691057
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
Harry Dredge
Sep 2, 2015 02:26 PM
