jaguar x type 400x estate 2ltr duratourqe
Old Sep 16, 2020 | 12:23 PM
tigerwarrior's Avatar
Unhappy jaguar x type 400x estate 2ltr duratourqe
can any one help my estate has 2ltr duratourqe engine i have fitted full new timing kit pluss 4 recon injectors done at my locale garage BUT when you try to acselorate up to 2000 rps it cuts out no smoke no rattle start up again you can drive faward and backwards but when you apply ecselorator it cuts out around 1800 to 2000 ???? can any one help
Old Sep 16, 2020 | 04:36 PM
Man on the hill's Avatar
Your problem sounds like a fuel pressure issue.
Assuming you have fitted a new fuel filter, have you read any diagnostic codes ?
Check leak off on the recon injectors, excessive leakage will drop fuel pressure under demand.
Paul.
Old Sep 23, 2020 | 02:27 PM
Wight8's Avatar
Check the gap on the crank sensor, when it was removed to insert the timing pin if it was replaced slightly too far out it will give an issue exactly like that - assuming your description is accurate about RPM, dead cut out and not load based cut out..
Either replace with new (Denso not ebay special)) and insert all the way - they have a sacrificial tip, or insert the old one and back out 1mm then tighten the bolt.
NB this issue does not always generate a code and sometimes it generates one for the cam sensor despite the issue being with the crank sensor.
Joshua McKnight
Jun 16, 2020 10:08 AM
Camnelson324
Mar 31, 2014 05:40 PM
Chad Wilson
Jul 10, 2013 12:46 PM
llesg
Apr 19, 2013 02:42 PM
soonerpride316
Jun 12, 2010 08:15 AM
