jaguar x type auto transmission problem
Old May 18, 2014 | 03:47 PM
rebmottel's Avatar
Default jaguar x type auto transmission problem
Hi all, I'm new here so go easy on me!
I have stumbled upon a 2001 jaguar x type 2.5 awd auto with lpg conversion with just over 50k on the clock, the thing is like this, when you first start the car it drives and reverses no problem then after a minute or 2 it starts slipping and looses all sense of drive switching the car off waiting about 15 - 20 seconds it will work then the problem will come back, it does pop up and say transmission fault now and then accompanied by the check engine light but not always, even when there is no drive, I have changed the transmission fluid twice with no luck, although the first time there was abit of metal shavings on the sump plug.
Any help or advise would be much appreciated.
Old May 18, 2014 | 04:02 PM
rebmottel's Avatar
If it helps I'm from England so its a right hand drive.
Is the gearbox a dead? or is it maybe a problem with the transmission control module, or something as simple as some sort of sensor.
Again anyone's input would be much appreciated.
Old May 18, 2014 | 05:53 PM
Welcome to the forum rebmottel,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Rupesh
Mar 25, 2016 03:33 PM
Steve Langridge
Sep 3, 2015 07:35 PM
NorJag
E type ( XK-E )
Aug 28, 2015 07:31 AM
gene1
Aug 27, 2015 08:56 PM
Terrance Williams
Aug 26, 2015 11:50 AM
