Jaguar XK wheels onto my X-Type
Old Aug 2, 2009 | 07:52 AM
Thermo's Avatar
Veteran: Navy
Richie, I think you are going to have perpetual problems with these rims regardless of the tire size that you fit on there. The XK wheels are 8.5" wide where the factory 17" X-type wheels are only 7.5" wide. This is a significant difference and the X-Type doesn't have a lot of spare room in the wheel wells. If you are going to have a chance, you will need to step down to 235/40R18's and put those on the rim. But then, you are going to find that the rim is going to be wider than the tire and is going to leave the rim open to lots of damage.
I would tell you to try putting the 245's on the car as is and without moving the car, try turning the wheel and seeing if you get any rubbing. You don't want to move the car as the tires will be different sizes and this can lead to problems with the transfer case (all tires need to be the same size). So, at a minimum you will need to buy 2 new tires (replacing the 275's) so all your tires are 245's. But then, that may lead to the issue I was talking about before in that the rear rims are wider, which will lead to a visual problem. Sounds like too much hassle for me.
Wish you luck if you do attempt to get this done.
rvdz
Dec 7, 2019 06:42 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
h4wk
Nov 27, 2015 05:10 PM
EastFalk
Aug 29, 2015 08:22 PM
J-Rock
Aug 25, 2015 08:33 PM
