jatco jf506e only drives in reverse
Old Sep 17, 2018 | 06:25 AM
iownme's Avatar
Default jatco jf506e only drives in reverse
so not an x type but i believe the same transmission right ?
im looking at buying my neighbor a 2004 landrover freelander....issue is that it only drives in reverse.
lots of info when there is a NO reverse condition but very little for a "no forward gears" condition
anyone have this issue with this transmission?
Old Sep 17, 2018 | 08:43 AM
Thermo's Avatar
Veteran: Navy
I would start with checking the fluid level. If the fluid gets too low, it can cause the tranny to not develop enough pressure to put the tranny in gear. Yet, may still go into reverse. After that, you are most likely looking at a bad tranny pump or something clogging the fluid ports.
Old Sep 17, 2018 | 09:24 AM
iownme's Avatar
thanks....im going to take a quart of atf with me.
tons of info about NO reverse online... lol
ive never worked on a trans before but im thinking this might be a cheap(ish) way to learn,
im also leaning toward low fluid
a. because too little info out there
b. reverse gear is at bottom of the gear stack from what ive seen
Old Sep 17, 2018 | 03:23 PM
Dell Gailey's Avatar
Here you go iownme, if it is not the linkage components (as you know) or the fuse, this has a post in it from a mechanic that found the problem. Based on no "limp mode" & no codes thrown.
https://the75andztclub.co.uk/forum/a.../t-173693.html
This one has disassembly pics =
http://www.the75andztclub.co.uk/foru...d.php?t=140572
You can also search for VW 09a (what they call the 506e)
Old Sep 17, 2018 | 08:47 PM
iownme's Avatar
thankyou gents!
after much reading it looks do-able,
possibly a cracked reverse piston as
most of these common trans issues
seem to be from that, couple of other
possibilities too.
so its about time i tried.
the car is super clean, no rust and
91000...$700
the job can be done insitu and will be handy
to know for the x typers too
Old Sep 18, 2018 | 07:39 PM
iownme's Avatar
car was nothing like as stated and his explaination for the gear issue was siuspect!!.
i walked away from that one! but learned a lot in a short time about the X transmission, so thats a good thing ;@)
Lude
May 25, 2024 03:51 PM
xtypeofjag
Nov 12, 2014 01:53 AM
notch383
Oct 15, 2014 10:08 PM
Vic Douse
Jul 25, 2013 05:50 AM
Yaguareté
May 31, 2013 06:52 PM
