jerking steering wheel
Old Jun 18, 2008 | 03:27 PM
aquill1's Avatar
Default RE: jerking steering wheel
Could be a number of things...hopefully someone could help you out...try going to a local tire shop to check out the rims?
Old Jun 18, 2008 | 04:18 PM
jvegas's Avatar
what is "slow speeds" and does it go away at high speeds?
Old Mar 2, 2010 | 10:07 PM
Disco stu55's Avatar
i have the same probelm, i jus tnoticed after my whole system was replaced after the curb incient. but i am driving on a donut
Old Mar 2, 2010 | 10:50 PM
Real_Tech's Avatar
Default Just about 100% sure it's not alignment
It's a bad tire. The low speed large displacement of the steering wheel can only mean one thing..... a seperated belt in one of the front tires. This is nothing to play around with. If your loved ones ride or drive in this car you need to fix it now not next week. If you can't buy a new tire put the spare on even if it's a mini. That tire will blow at any moment, low or high speed and it is causing the pull as well. To tell you the truth 95%++++ of pulls are caused by tires not alignment specs being out by a tenth of a degree. You can easily test this for yourselves. The next time you find your car pulling check the air pressure. If it is good and even side to side on the front axle and the car pulls to one side just swap the 2 front tires side to side. I have a twenty spot that says you car will now pull the opposite direction or go straight. Be warned, if you come to collect that 20 I'm going to swap your tires side to side.
Old Mar 2, 2010 | 11:14 PM
fudge, i need to order the new rim and get that done, i can't belive they would ut a faulty tire into a spare. Its just deosn't amke sence
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
1964Daimler
Sep 9, 2015 11:28 AM
