Key fob will not pair
Old Feb 24, 2017 | 07:58 AM
tad843's Avatar
Unhappy Key fob will not pair
I have a 2002 x type. The key fob will not pair I've replaced batteries and even replaced the lower fob. When I got to pair it I hear the car chime but can never get it to chime when I'm pushing the key fob buttons. Any ideas?
Old Feb 26, 2017 | 04:08 AM
JWRussell's Avatar
Default Key Fob
The key fob for my 2001 2.5 Se recently ceased to work. I replaced the battery's in both fobs ( the reserve fob having failed some time ago) I then followed the programming procedure but failed to get a 'bleep' after tuning the ignition key the stated 4 times between 1 and 2 ?
Any suggestions .
Old Feb 26, 2017 | 08:08 AM
jagger's Avatar
Fobs sometimes fail because of the switches. There are two things that often happen in older fobs. The first is that the switches break their solder joints to the circuit board. There are 4 solder connections on each switch. Sometimes only one breaks and and it looks OK unless you use a microscope. Sometimes all 4 break and the switch falls out of position. I have heard of people re-doing the solder.
The other problem is corrosion which appears as green gunk around the switch. I don't know if this can be fixed.
Pete.
Old Feb 26, 2017 | 12:14 PM
santer's Avatar
Originally Posted by JWRussell
Any suggestions .
Most on the UK Forum use fingazfobz
" If, for any reason the fob is not repairable, you will receive a FULL refund of the purchase price, MINUS the cost of return shipping to send your fob back "
fingazfobz | Fob Repair Service
Old Feb 28, 2017 | 08:32 AM
iownme's Avatar
i have seen several different sets of instructions for this.
some did not work for me.. the following link did
http://www.bluejag.co.uk/X-Type-keyfob-reprogramming.php
