Key Stuck in Ignition - On Position
Old Jul 11, 2016 | 12:06 AM
adamh149's Avatar
Default Key Stuck in Ignition - On Position
Hi all,
My ignition key has become stuck in the 'on position', won't allow me to turn it off. The only way to stop the engine was to remove the fuse for the fuel pump to stop the engine and then to disconnect the battery to stop it draining as the electrics would still be on. The key still stubbornly refuses to turn to off. It will allow me to turn it to the position to start the engine and then back to on again, but not off! The vehicle is in park and seems to recognise this as when I move it through Reverse and Drive, the car responds and then stops when in park.
Any ideas please?
Thanks, Adam.
Jaguar X Type. 3.0L V6 Premium Sport, Auto, AWD.
Old Jul 12, 2016 | 06:37 PM
hlgeorge's Avatar
Did you try spraying a little lubricant into it?
Old Jul 13, 2016 | 07:02 AM
avern1's Avatar
If lubricating it didn't resolve the key sticking I would recommend removing it and taking it to a locksmith that is familiar with Tibby keys. I have attached the removal instructions to assist.
If it can't be repaired you will have to replace it and that will require programming it to the PATS system.
File Type: doc
Jaguar Forums Editor
XE ( X760 )
Aug 15, 2016 06:20 PM
F-Pace (X761) / C-X17
Jul 6, 2016 04:13 PM
amillsmcewan
Jun 16, 2016 02:24 PM
anoop
XE ( X760 )
Jun 2, 2016 07:28 PM
pwpacp
Apr 18, 2016 05:28 PM
