LED bulbs for the parking lights
Old Nov 10, 2013 | 06:20 PM
04xtype04's Avatar
Default LED bulbs for the parking lights
Looking on ebay for the front LED parking lights (194). There are quite a few different styles of LED lights and I was wondering which style worked best? Maybe the larger CREE led's vs. the smaller led lights? Also which have you found are bright enough and last? I heard heat from the high beams can be an issue. Thanks.
Old Nov 10, 2013 | 06:37 PM
Thermo's Avatar
Veteran: Navy
zach, I think you are going to find that the CREE light setup is going to be the way to go. You don't really save anything in the way of power, but you will get lots more light out of the CREEs.
As for the heat destroying anything that you put in there, I guess it depends on how much you use your high beams. For most people, the amount of time that the high beams are on is going to be relatively insignificant in the big picture of things. If you live in a rural area, then yes, it may be a factor. If you are worried about heat, then I would stick more with the CREEs than LEDs. The CREEs are going to take the heat a lot better than the LEDs are going to.
Old Nov 10, 2013 | 10:16 PM
aCapiz's Avatar
I completely agree with Thermo. I have a set of Cree Q5 Leds in my reverse lights and the brightness of these blow all of my other LEDs out of the water. You won't regret it. My reverse lights are much brighter than the incandescents I use to have.
99xk8guy
May 28, 2024 09:36 PM
afterburner1
Dec 16, 2015 12:12 AM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
sklimii
Sep 5, 2015 06:04 AM
