LED's on the inside
Old Jan 28, 2008 | 10:32 PM
jvegas's Avatar
Default LED's on the inside
I recently put LED lights over the license plate. They look good and now I want to change the interior lights to LED’s.
As far as I can tell there are:
2 map lights
One front dome light
One rear dome light
one light in the glove box
Two front foot well lights
I looked around and could not find out what size/type bulbs these all take. Does anyone happen to know? Also is that orange accent light in the over head consol that lights the lower consol, is that a regular bulb? And how hard do you think it would be to? and did i miss any lights?
Old Jan 29, 2008 | 09:35 AM
jvegas's Avatar
Default RE: LED's on the inside
wow 14 hits.... not one reply. i bet gotti knows.
Old Jan 29, 2008 | 12:46 PM
Hey there jvegas.....lol@ your comments
[sm=icon_rtfm.gif].....lol
Sorry I can't help, but have you tried looking in the owners handbook? You'll probably find all the info on this there I woulda thought!
Good luck
Jim
Old Jan 29, 2008 | 03:03 PM
jvegas's Avatar
yup i looked there but it did not list the bulbs.
Old Jan 29, 2008 | 04:35 PM
Cadillac's Avatar
I seen worse than that on other forums lol
Old Jan 29, 2008 | 05:27 PM
aquill1's Avatar
Should be listed inside there...only other thing is to pull the bulbs out and figure it out...
Old Jan 29, 2008 | 06:03 PM
jvegas's Avatar
i know gotti had some list he posted but it only had the exterior lights listed. i was hoping that someone had a list of the inside lights.
Old Jan 30, 2008 | 12:09 AM
gotti15's Avatar
I was actually thinking about doing the same thing to my interior. I switched out the bulbs in the foot wells and I didnt like the way it looked. I looked too much like an import car. No offense, but just not my style.
The foot well bulbs are 194. But I have no idea how to change out the front & rear dome or map lights. Let me know if you found out what types of bulbs for the domes.
I'm interested in seeing how it looks.
Old Jan 30, 2008 | 08:40 AM
jvegas's Avatar
will do. i was hoping you would read this gotti, i have another idea. what if there was a way to put dim bulbs in the foot wells and have them on when ever the had lights are on? like while you are driving. that might be kind of cool? i will let you know once i find out what kind of bulbs the rest of the car takes.
Old Jan 31, 2008 | 06:23 PM
gotti15's Avatar
Cool. Let me know how it comes out.
I'm not sure of havingthe foot well lights on while driving. I guess it would be kinda cool when cruising on a strip or something, but maybe a little with everyday driving. LOL
Old Feb 1, 2008 | 09:08 AM
RedJag's Avatar
I thought the Jag was an import....please tell me its not one of those pretend imports built in South Carolina....
Sorry Gotti....I had too!
Old Feb 1, 2008 | 04:46 PM
gotti15's Avatar
LOL. Nice one RedJag. You know what I meant! It'll look too "Fast and the Furious" for me! LOL!
Old Feb 1, 2008 | 07:39 PM
RedJag's Avatar
[sm=icon_cheers.gif] LOL...checked out your CarDomain, nice set up on the X! I'm with you on the F&F look....not for me either.
Old Feb 3, 2008 | 11:16 AM
jvegas's Avatar
i got the new leds today! they all look good but the tail lights. i don't like them they are too dim.... dimmer then the OEM bulb. maybe i got the wrong ones but for now i switched them back to the OEM bulb. i am still waiting on my HID's i ordered last week. 6k from mydepots.... i cant wait!
Old Feb 5, 2008 | 02:29 PM
jvegas's Avatar
i did not get the led's for the inside yet just the outside. i am still trying to find out what the inside lights take.
Old Feb 5, 2008 | 05:49 PM
H20boy's Avatar
Jvegas, i've been testing a BUNCH of LEDs for brake/tail/turn signals, and am going to write up a general opinion thread showing the different types, and which ones are best suited for which application, brightness compared to original bulbs, etc. To give an idea, the turns are easily replacable with an LED alternative, but the brake/tail bulbs are the most difficult. I have three new styles arriving this week that I am testing, then will put together a summary page for everyone to use if they want.
HIDs...they should be there any minute!
Old Feb 5, 2008 | 06:12 PM
FactoryJaguarTech's Avatar
Interior Lighting
The interior lighting system consists of the following components:
[ul][*]One front interior lamp.[*]Two map reading lamps.[*]Two front footwell lamps[*]One rear interior lamp.[*]Two front door/puddle lamps[*]One glove compartment lamp.[*]Two vanity mirror lamps.[*]One luggage compartment lamp. [/ul]The automatic operation of the interior lights is controlled by the general electronics module (GEM). Pressing the interior lamp switch in the overhead console switches the interior lighting control from automatic to ON position. When the switch is in the ON position if any of the doors are open, only the rear interior lamp can be turned off.
If the rear interior lamp switch is in the AUTOMATIC position, the front interior lamp switch can operate the rear interior lamp.
In the AUTOMATIC position, when the interior lights have faded out, each lamp can be switched on or off by pressing the associated switch.
If the interior lamps are switched on and the ignition switch is turned to the OFF or ACCESSORY position the lights will automatically turn off after ten minutes.
With the switch in AUTOMATIC position the following times apply to the interior lights fading out assuming lights on.
Condition Fade out time Open any door with key not in ignition, close door Lamps will fade out after twenty seconds With engine in RUN position and open any door, close door Lamps will fade out immediately Open any door, switch ignition to the RUN position, close door Lamps will fade out immediately
Item Specification
Front turn signal lamp bulb PY21W
Front fog lamp bulb H1-55W
Parking/Side lamp bulb W5W
Low beam lamp bulb H1-55W
High beam lamp bulb H1-55W
High intensity discharge (HID) lamp bulb D2s-35W
Rear turn signal lamp bulb PY21W
Rear fog lamp bulb P21W
Stoplamp/rear lamp bulb P21/5W
Rear lamp bulb P21/5W
Reversing lamp bulb P21W
Side repeater lamp bulb W5W
Side marker lamp bulb W5W
Sorry but no specs listed for interior bulbs.
Old Feb 5, 2008 | 08:20 PM
jvegas's Avatar
thanks anyways
