Low Pitched Whistle
Old Feb 3, 2011 | 03:01 PM
JaguarKnight's Avatar
Default Low Pitched Whistle
I had a vacuum leak that was throwing codes P0171 and P0174, so yesterday I changed the IMT o-rings, the PCV hose, and the brake booster hose. That fixed the vacuum leak, but now I have a low pitched whistle. It only happens once or twice when I first start driving, then goes away. It is not a whine, nor wind noise. It is short duration, maybe 2 seconds, and the pitch is about like the whistle you get when you blow across the top of an empty soda bottle, but somewhat louder. The car is a 2002 X-type 2.5L with auto transmission. Any ideas?
Old Feb 3, 2011 | 06:07 PM
jaglover922's Avatar
drive shaft center bearing? Does it happen when slowing down or when engine braking.
Old Feb 4, 2011 | 11:41 AM
It started immediately after I fixed the vacuum leak. Now, however, after driving it around for a day, it stopped. So I guess that some part of the vacuum system was not seated properly. Perhaps the brake booster valve needed to "wear in." Anyway, it seems to be done, so I am not going to worry about it unless it starts again.
Old Mar 18, 2011 | 10:14 AM
Update: it still happens occasionally, when the engine has been stopped for a while. It is just a short whistle, and then it stops. It is not too annoying, so I am going to ignore it unless it gets worse.
X308XJR
May 20, 2019 06:50 PM
tampamark
Oct 11, 2015 10:03 PM
Old_Doc
Sep 29, 2015 03:43 PM
sg997tt
Sep 29, 2015 08:13 AM
sg997tt
Canada
Sep 27, 2015 02:40 PM
