Lower Radiator Hose Trouble
Old May 28, 2012 | 09:53 PM
Erndiego619's Avatar
Default Lower Radiator Hose Trouble
What up Jaggys! Hope everyone had a great weekend. I had some trouble with my 03 x type. The lower radiator hose came loose on the freeway. When I checked it out I noticed that the pin that holds it in placed came loose, so I put the hose back on set the pin in place checked to see if I could put it loose with my hand but was well on there so thought problem fixed. A few days later at a stop light same thing happend again. This time when I put the hose back on I could see stat the pin would start to slip out when I pulled on the hose with my hand to make sure the hose was on there. I wanted so know if there is a better way to secure that hose myself with a clamp or is there a better way to do it any feed back would be great. thanks your friend Erndiego.
Old May 29, 2012 | 04:42 PM
disguay's Avatar
I would either get a hose clamp, or I would grab a new lower radiator hose from rockauto.com. Hopefully one of the two will allow a snug fit back onto the underside of the radiator.
Old May 29, 2012 | 10:15 PM
Thanks for the reply I post After the clap is on for awhile to test out first if not I get the hose instead. Thanks again.
Wahooesprit
Dec 23, 2019 02:01 PM
mhamilton
Sep 12, 2015 03:21 PM
1964Daimler
Sep 9, 2015 11:28 AM
1100me
Sep 7, 2015 06:26 AM
