Lower Thermostat Hose
Old Sep 25, 2025 | 07:05 PM
Gdt928's Avatar
Default Lower Thermostat Hose
While reassembling everything after the upper radiator hose and thermostat housings swap, I noticed the stubby hose connecting the bottom of the thermostat to the aluminum pipe for the radiator had a small split in the upper edge. Sourcing a replacement has gotten crazy. Wouldn't a piece of automotive radiator hose of the same inside diameter work is a replacement? This hose apparently is a heavy rubber.
Old Sep 25, 2025 | 09:10 PM
Dell Gailey's Avatar
https://jaguar.oempartsonline.com/v-...and-components
Old Sep 25, 2025 | 10:36 PM
95naSTA's Avatar
I ended up finding a Gates EPDM hose (p/n 22024) with the same ID, 1.42"ish, and cutting it to length. No issue since. It was $12 when I ordered it back in '21.
I feel like I somehow found the hose separate after I did this but I didn't save that anywhere.
Old Oct 17, 2025 | 07:44 AM
iownme's Avatar
ah yes, its been a while....but i remember that view well!
Evan97
Sep 7, 2024 12:53 AM
PeteK812
Feb 22, 2016 03:08 PM
Fishfoolbear
Feb 23, 2015 03:02 PM
and1carter
Mar 7, 2014 08:02 AM
DaveC
Dec 22, 2012 02:21 PM
