Manifold Gaskets Help!
Old Apr 19, 2012 | 01:27 PM
Strafe's Avatar
Exclamation Manifold Gaskets Help!
I'm going to be changing the upper and lower gaskets. I found these online:
This set is only $26.00. Can I get two sets and do both upper and lower with these? Or are the lowers different?
Felpro Intake Manifold Gasket - Auto Parts Warehouse
I also found these. But they are like $16 each gasket. Anyone have a clue why they'd be that much?
Upper - http://www.motorcarsltd.com/XR843536.html
Lower - http://www.motorcarsltd.com/xr843533.html
Any insight as to these or where I can purchase them all online at a good price would be appreciated.
Thanks!
Old Apr 19, 2012 | 05:01 PM
Thermo's Avatar
Veteran: Navy
Strafe, you want the parts from Motorcars LTD. Between the two parts, that will do both sections that are likely to cause you issues. If you are into the intake for the upper gaskets, it is just a little more work to do the lowers since you are in that far.
Old Apr 21, 2012 | 01:10 PM
Strafe's Avatar
Hey Thermo, sent you a PM.
Poet
Feb 7, 2025 02:18 PM
X308XJR
May 20, 2019 06:50 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
BSM
Sep 25, 2015 05:00 PM
