Most Current Alignment Specs?
Old Feb 8, 2024 | 01:28 PM
BuckleSpring's Avatar
Default Most Current Alignment Specs?
Just finished up doing a front-suspension rebuild of my X-Type and was wondering is anyone had a PDF or knew of what the most recent alignment specs should be when I go to have it aligned soon.
I've found the TSB from February 2006 that states:
But according to the Jaguar Vehicle Specifications PDF from September 2009, it states:
- Front Toe of: -0.10º, for a total of -0.20°
- Rear Camber of: – 0.70°
- Rear Toe of: +0.125°
From all the sources I've found, they seem to pretty much agree on the rear specs... But which is the most current/recommended spec for the front Toe? My car is a US-Spec 2006 3.0 AWD Wagon for reference. Some people have mentioned going with Mondeo Estate specs?
Old Feb 8, 2024 | 05:24 PM
Thermo's Avatar
Veteran: Navy
This was something that I found in my references which is looking very close to what you have, just called out a little bit differently:Note:
Settings must be checked with the vehicle at 'curb' height (unladen, with full tank of fuel).
Front Suspension
Camber
Left Hand
-1.04°to -0.04°
Right Hand
-1.04°to -0.04°
Balance (RH minus LH)
-0.70°to +0.70°
Caster
Left Hand
+1.98°to +2.98°
Right Hand
+1.98°to +2.98°
-0.50°to +0.50°
Toe
-0.27°to +0.07°
Rear Suspension
Camber
Left Hand
-1.20°to -0.20°
Right Hand
-1.20°to -0.20°
-0.50°to +0.50°
Toe
Left Hand
+0.03°to +0.23°
Right Hand
+0.03°to +0.23°
Total Toe
+0.08°to +0.42°
Thrust Angle
-0.10°to +0.10°
Alignment Specifications
Old Feb 8, 2024 | 05:44 PM
Originally Posted by Thermo
Toe -0.27°to +0.07°
Interesting, I haven't seen this referenced anywhere. That's basically -0.12, +-0.15. I assume that's total specified toe?
This is the current chart I've made from the different TSB's and other data I've found.
Old Feb 9, 2024 | 10:38 AM
Dell Gailey's Avatar
Mpowerr
Apr 7, 2024 08:36 AM
lc3566
Apr 8, 2016 08:33 AM
bfsgross
Oct 4, 2011 08:57 AM
phd12volt
Aug 7, 2009 11:24 AM
Thermo
Jun 30, 2009 07:07 PM
