Multiple Misfire and Cruise not available?
Old Jun 23, 2009 | 09:03 AM
JagXV6's Avatar
Here you go:
https://www.jaguarforums.com/forum/s...highlight=ring
Old Jun 25, 2009 | 09:46 AM
Jaguardoc504's Avatar
In my experience it wouldnt be a stretch to assume the coils are bad. However it def. sounds like a vacum leak. Check the intake manifold seals as well. try using a little bit of prorane/hair spray/ around the intake if you get a fluctuation in the idel then you know you have a leak.
GL
Old Jun 26, 2009 | 06:22 PM
TexJag's Avatar
I had the same problem at 127,000 miles. A couple of the coils were bad when they tested them. Replaced them all and the plugs. What a difference. Even gained better gas miliage and acceleration.
Old Jun 28, 2009 | 01:57 PM
Chas944's Avatar
I had this very same problem 2 months ago. First thing I checked was vacuum hoses. My culprit was the large diameter hose running from the PCV valve on the A-side bank (close to front of hood) to the intake for the positive crankcase ventilation. The original hose is smooth and had a 2" long rip in it. When I twisted the hose back and forth it either closed the rip or opened it wide open.
The updated hose has reinforcement ribs for strength.
Hope you find the problem soon. You can always take your car to an Advanced Auto or Auto Zone and have the codes run.
Old Mar 29, 2018 | 11:28 PM
haroldjoling's Avatar
there is a ground wire which can affect the coils when corroded or broken.
Old Mar 30, 2018 | 07:56 AM
Spanishlion's Avatar
what colour is the ground wire from the coils and where does it connect to the ground point.
aode06
Jul 28, 2023 02:26 PM
goingjag
Sep 30, 2015 09:27 PM
JTC3400
Sep 29, 2015 05:03 PM
reb1999
Sep 26, 2015 08:41 AM
