My engine is shot
Old May 18, 2014 | 10:01 PM
04xtype04's Avatar
Default My engine is shot
My engine clunked as I went over a railroad crossing today. I smelled burning plastic and saw smoke in the rear view mirror, then the engine shut itself off and I coasted to a stop. I opened the hood and the engine was smoking from the rear valve cover area. I checked below and it was just dripping oil out all over the ground and all the oil leaked out. Had to get it towed. Not sure what the damage is. The engine must have a crack in it somewhere. Smoke and oil pouring out, not good.
Old May 18, 2014 | 10:28 PM
car5car's Avatar
jack it up and take a look.
Turn crank by pulley bolt, I think, it is 3/4" 19 mm
Maybe there is a hole in oil pan and ECU turned engine off?
Old May 18, 2014 | 10:36 PM
04xtype04's Avatar
But why the thud/breaking sound and the smoke off the top of the engine?? Something internal must be broken. The car shut off before the oil leaked out.
Old May 18, 2014 | 10:42 PM
car5car's Avatar
Guessing doesn't make sense, engine has to be checked/diagnosed.
Was engine overheated?
Old May 18, 2014 | 10:54 PM
04xtype04's Avatar
Nope. That's the weird thing. Wasn't overheating and no check engine lights.
Old May 18, 2014 | 11:28 PM
Spikepaga's Avatar
Sorry about your troubles.
If it's any consolation, in my experience, the most dramatic failures my Jaguars have given me (puffs of smoke, terrible noises, etc) have typically been the cheapest things to fix.
Old May 19, 2014 | 07:03 AM
ltmax's Avatar
I wonder if your transfer case broke and punched a hole in the case.
Old May 19, 2014 | 08:16 AM
Alfadude's Avatar
'04, sorry to hear that. Definitely doesn't sound good. Hope whatever it is it is fixable so you can get back on the road, especially after all the time and money you have put into it the last several months. I can't offer any advice, only my sympathy. Hang in there and let us know what ended up happening.
Old May 29, 2014 | 08:24 AM
Alfadude's Avatar
Hey. '04. Just thought I would check in and see what ended up being the issue with your car. Hope it wasn't something terminal. Any idea what happened and what might have caused it?
Old May 29, 2014 | 11:56 PM
04xtype04's Avatar
The only thing I can think that did it that was this hard bump in an intersection and that rattled something loose, or maybe someone sabotaged it while I was in the casino, I don't know. It was basically a normal drive. I had a lot of people with me but we weren't really going that fast the way up there. No crazy revving or anything. Then I get there and it's just rattling like something got loose. Then I drive it home and it starts rattling a lot by the time I get there. I drove it for about 5 minutes the next day and the engine breaks down over the tracks but I coast it down the road a minute or so and see all the oil spilling out. Now I have to install a whole 'nother engine!
Old May 30, 2014 | 07:33 AM
Paulc732's Avatar
Sorry to hear your trouble.
check out this post.
https://www.jaguarforums.com/forum/x...ype-jag-34228/
I know your good with mechanical things based on your prior work.
would be cheaper if you buy an engine hoist and do the work your self its not that hard.
check your local scrap yards
Old May 30, 2014 | 09:03 AM
car5car's Avatar
Before making decision you need to know what happened. Probably you need to remove oil pan if there is no external holes.
Old May 30, 2014 | 09:10 AM
Alfadude's Avatar
That's a tough one, especially after you put all that work into it. Hope you find a suitable engine to replace it that doesn't cost too much. Hope you are back on the road soon.
Old May 30, 2014 | 09:44 AM
Mikey's Avatar
Maybe these were warning signs?
https://www.jaguarforums.com/forum/x...-stops-118020/
https://www.jaguarforums.com/forum/x...-sound-117262/
Old May 31, 2014 | 04:45 AM
Jac's Avatar
Jac
04xtype04, Sorry to hear about your engine problem. It doesn't sound good. Hope the best for you in getting it fixed. Too bad that a certain person on here just wants to make a joke about it. I think HE needs his muffler bearings changed.
Old Jun 1, 2014 | 09:42 PM
car5car's Avatar
Jac, I was repairing engines for 20 years, but I cannot suggest anything until I know what happened.
Old Jun 1, 2014 | 10:44 PM
Tony_H's Avatar
There are a lot of "it's broken, what's wrong with it?" posters here. If after one or two posts he's not willing (or capable) to detail his problem or do any work to sort out then just forget about it. On the other hand there are also a lot of people here with a lot of experience who could really help if the person with the problem just put in a little effort.
Old Jun 2, 2014 | 04:00 AM
Jac's Avatar
Jac
Your right Tony, And I agree. But maybe you missed the post that he had on here (Before he deleted them) about checking the point breakers and another one about adjusting the carburetor. Anybody that worked on cars for 20 years should know that they don't even use them anymore.
Old Jun 2, 2014 | 08:25 AM
Tony_H's Avatar
That just reinforces my point. Those comments make me think that this guy is just a troll???
Old Jun 2, 2014 | 12:21 PM
car5car's Avatar
Jac, you missed smiley face.
I am not a troll, I am just trying to repair X-type for my wife. I repaired engine already, but it still has some other problems beside reclearing front bumper.
