A/F ratio
Unless you've done something seriously radical, the ECU will compensate. If you've done something so radical that the airflow is outside the ECU's parameters, you're likely looking at upgraded injectors and a remap of the ECU and a few cubic dollars. Maybe someone here knows a tuner. I'm under the impression that the X100's ECU code is proprietary and not many tuners will futz with it.
ben mensforth
Jul 3, 2024 07:24 AM
lcyoung
Sep 10, 2012 08:57 PM
